Removing Convertible top molding #615470
02/17/10 12:53 PM
02/17/10 12:53 PM
Anonymous OP
Anonymous OP
Getting ready to remove the molding around the trunk for paint. How are they held down? Has anybody ever done this on a 1969 Coronet?
Thanks,
Bill
Re: Removing Convertible top molding [Re: ] #615471
02/17/10 01:22 PM
02/17/10 01:22 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I've done it on a Challenger. Had to remove the top to get at the screws from the underside
CHECK OUT MY NEW WEB SITE !
Re: Removing Convertible top molding [Re: anlauto] #615472
02/17/10 02:10 PM
02/17/10 02:10 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Yep they have studs with nuts holding them on.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Removing Convertible top molding [Re: anlauto] #615473
02/17/10 02:12 PM
02/17/10 02:12 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Do you mean the surround mouldings common to your dutchman panel and quarter windows?
Quarter window mouldings are held in place by 4 or five flush screws which hold it to inner body panel.
Surround mouldings are held in place by phillips screws which pickup clips inside mouldings. They are accessed from beneath. You can get at them with the top stowed but will need an angle phillips as there is not a lot of room.
The pot metal pieces have a sheet metal screw on each end.
Re: Removing Convertible top molding [Re: 70mopes] #615474
02/17/10 05:09 PM
02/17/10 05:09 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
As stated above, also a stubby Phillips works well. Ron
Re: Removing Convertible top molding [Re: RJS] #615475
02/20/10 10:27 AM
02/20/10 10:27 AM
Anonymous OP
Anonymous OP
Thanks for the info. Just like you said, put top down and unscrew.Got the molding off.
Thanks,
Bill
Re: Removing Convertible top molding [Re: ] #615476
06/16/10 07:56 AM
06/16/10 07:56 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Does anybody have a picture of what these moldings look like up close?
