Removing Convertible top molding
#615470
02/17/10 12:53 PM
02/17/10 12:53 PM
Getting ready to remove the molding around the trunk for paint. How are they held down? Has anybody ever done this on a 1969 Coronet? Thanks, Bill
Re: Removing Convertible top molding
[Re: anlauto]
#615472
02/17/10 02:10 PM
02/17/10 02:10 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Yep they have studs with nuts holding them on.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: 70mopes]
#615474
02/17/10 05:09 PM
02/17/10 05:09 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Do you mean the surround mouldings common to your dutchman panel and quarter windows?
Quarter window mouldings are held in place by 4 or five flush screws which hold it to inner body panel.
Surround mouldings are held in place by phillips screws which pickup clips inside mouldings. They are accessed from beneath. You can get at them with the top stowed but will need an angle phillips as there is not a lot of room.
The pot metal pieces have a sheet metal screw on each end.
As stated above, also a stubby Phillips works well. Ron
[Re: RJS]
#615475
02/20/10 10:27 AM
02/20/10 10:27 AM
Thanks for the info. Just like you said, put top down and unscrew.Got the molding off. Thanks, Bill
