Vaccum Diagram Needed
#613832
02/15/10 04:38 AM
02/15/10 04:38 AM
Posts: 33 Burbank Ca
bkilby
Burbank Ca
Hello everyone! This is my first post but I've been lurking around for a bit. I just bought a restored '73 Challenger with the 340 and am in need of a vacuum diagram to make sure the hoses are connected correctly. The car is having a high rpm issue that we're trying to cure. I figured we'd start with the basics like the vacuum hose routing etc. Anyone have a diagram or know where to find one online?
'73 340 Challenger and then some.
Re: Vaccum Diagram Needed
[Re: DAYCLONA]
#613834
02/15/10 08:24 AM
02/15/10 08:24 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613835
02/15/10 08:25 AM
02/15/10 08:25 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613836
02/15/10 08:25 AM
02/15/10 08:25 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613837
02/15/10 08:26 AM
02/15/10 08:26 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613838
02/15/10 08:26 AM
02/15/10 08:26 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613839
02/15/10 08:27 AM
02/15/10 08:27 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613840
02/15/10 08:28 AM
02/15/10 08:28 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#613841
02/15/10 08:28 AM
02/15/10 08:28 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: RapidRobert]
#613844
02/15/10 12:17 PM
02/15/10 12:17 PM
bkilby
Burbank Ca
RapidRobert, I just bought the car a little over a week ago so I can't say when or why it started. Everything on the car is new. That doesn't mean it's connected or installed correctly though, right? The engine is missing and sputtering at higher rpm. We think it's starving for fuel. Even though everything was new, we've replaced the basics just to eliminate them. Spark plugs, cap, rotor, resister, fuel pump, fuel filter and thermostat (was leaking). The timing has been set, carb adjusted. It's all helped but it's still not running right. Saturday, it decided to start stalling without warning. That's when I put a fuel filter and pump in. I used a see through filter and basically when it stalls, the filter is empty. Crack up the hose and the filter fills up again. So like I said, I want to start with the basics and work from there. With the vacuum diagrams that Dayclona sent, I can make sure it's all connected correctly and go from there. I know I can bypass the stuff but besides the way it runs, I want to have everything connected and functional anyhow. The car: ![](http://www.dehesa4x4.com/bkilby/photoalbum/1973_Challenger/E-Engine.jpg)
[Re: RapidRobert]
#613846
02/15/10 05:41 PM
02/15/10 05:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Might put a can of gas in the eng compartment hooked to the pump inlet & take her out. What are you meaning by "crack up the hose"
Just a shot in the dark, High RPM issuses aside, the stalling and dry filter sounds like the tank isn't properly vented, or clogged vent wise, or incorrect vented/non vented gas cap, causing suction/vacumm in the tank/line?
Mike
[Re: RapidRobert]
#613847
02/16/10 01:08 AM
02/16/10 01:08 AM
bkilby
Burbank Ca
Oops! Typo! I meant to say "crack open the hose". In other words, when I opened the hose on the outlet side of the filter, it filled the filter with gas. More on that in a bit. Quote:
[Re: RapidRobert]
#613850
02/16/10 08:29 PM
02/16/10 08:29 PM
bkilby
Burbank Ca
Yeah, it was a light blue and is now replaced with a Standard Ignition dark blue. I'd rather have the Mopar box but I don't know where to buy them yet. Are they still available?
