Vaccum Diagram Needed #613832
02/15/10 04:38 AM
02/15/10 04:38 AM
Burbank Ca
bkilby Offline OP
bkilby  Offline OP
Burbank Ca
Hello everyone! This is my first post but I've been lurking around for a bit. I just bought a restored '73 Challenger with the 340 and am in need of a vacuum diagram to make sure the hoses are connected correctly. The car is having a high rpm issue that we're trying to cure. I figured we'd start with the basics like the vacuum hose routing etc. Anyone have a diagram or know where to find one online?
'73 340 Challenger and then some.
Re: Vaccum Diagram Needed [Re: bkilby] #613833
02/15/10 08:24 AM
02/15/10 08:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's everything from the 73 catalog, I'd look at the basics first, you may have a manifold installation problem causeing a leak, next EGR valve, carb/carb gasket, PCV system,....then troubleshoot the vac harness, click on the word "attachment" to enlarge
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613834
02/15/10 08:24 AM
02/15/10 08:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a2
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613835
02/15/10 08:25 AM
02/15/10 08:25 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a3
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613836
02/15/10 08:25 AM
02/15/10 08:25 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a4
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613837
02/15/10 08:26 AM
02/15/10 08:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a5
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613838
02/15/10 08:26 AM
02/15/10 08:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a6
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613839
02/15/10 08:27 AM
02/15/10 08:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a7
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613840
02/15/10 08:28 AM
02/15/10 08:28 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a8
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613841
02/15/10 08:28 AM
02/15/10 08:28 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
a9
Re: Vaccum Diagram Needed [Re: bkilby] #613842
02/15/10 10:03 AM
02/15/10 10:03 AM
What issue. When did it start. any changes/additions right before it started. If your suspecting a vac leak you could plug the intake vac source & take it out/run it up there & see if the prob dissapears.
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613843
02/15/10 12:00 PM
02/15/10 12:00 PM
Burbank Ca
bkilby Offline OP
bkilby  Offline OP
Burbank Ca
Thanks Dayclona! This one answers a second question I had, which was "what's the gizmo in front of the gas tank with 4 hoses going to the gas tank". I appreciate the pics!
a9
Re: Vaccum Diagram Needed [Re: RapidRobert] #613844
02/15/10 12:17 PM
02/15/10 12:17 PM
Burbank Ca
bkilby Offline OP
bkilby  Offline OP
Burbank Ca
RapidRobert, I just bought the car a little over a week ago so I can't say when or why it started. Everything on the car is new. That doesn't mean it's connected or installed correctly though, right? The engine is missing and sputtering at higher rpm. We think it's starving for fuel. Even though everything was new, we've replaced the basics just to eliminate them. Spark plugs, cap, rotor, resister, fuel pump, fuel filter and thermostat (was leaking).
The timing has been set, carb adjusted. It's all helped but it's still not running right. Saturday, it decided to start stalling without warning. That's when I put a fuel filter and pump in. I used a see through filter and basically when it stalls, the filter is empty. Crack up the hose and the filter fills up again. So like I said, I want to start with the basics and work from there. With the vacuum diagrams that Dayclona sent, I can make sure it's all connected correctly and go from there. I know I can bypass the stuff but besides the way it runs, I want to have everything connected and functional anyhow.
The car:
Re: Vaccum Diagram Needed [Re: bkilby] #613845
02/15/10 05:07 PM
02/15/10 05:07 PM
Might put a can of gas in the eng compartment hooked to the pump inlet & take her out. What are you meaning by "crack up the hose"
Re: Vaccum Diagram Needed [Re: RapidRobert] #613846
02/15/10 05:41 PM
02/15/10 05:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just a shot in the dark, High RPM issuses aside, the stalling and dry filter sounds like the tank isn't properly vented, or clogged vent wise, or incorrect vented/non vented gas cap, causing suction/vacumm in the tank/line?
Mike
Re: Vaccum Diagram Needed [Re: RapidRobert] #613847
02/16/10 01:08 AM
02/16/10 01:08 AM
Burbank Ca
bkilby Offline OP
bkilby  Offline OP
Burbank Ca
Oops! Typo! I meant to say "crack open the hose". In other words, when I opened the hose on the outlet side of the filter, it filled the filter with gas. More on that in a bit.
Re: Vaccum Diagram Needed [Re: DAYCLONA] #613848
02/16/10 01:15 AM
02/16/10 01:15 AM
Burbank Ca
bkilby Offline OP
bkilby  Offline OP
Burbank Ca
Dayclona, that's what I though too so I was focused on the the fuel stuff. The bottom line is, I replaced the ECU on a whim and [Edited by Moparts - Family Friendly Site - Keep it clean], the car runs like a champ! No high RPM miss, no engine stalling, nothing. I drove it around for an hour and besides the carb needing adjustment again, it runs better than the day I bought it. Last week! Heh heh! I literally took an item that was "brand new" and tossed it in the trash. I should have beat it with a hammer first but I didn't. So, the car is running good but I still want to check the hoses and stuff. Your schematics will make that easier and for that, I thank you.
Re: Vaccum Diagram Needed [Re: bkilby] #613849
02/16/10 01:30 AM
02/16/10 01:30 AM
I replaced the ECU on a whim. I literally took an item that was "brand new" and tossed it in the trash.
I'm glad you got it especially before tossing anymore (unneeded) parts at it. What color was the bad ((almost new) ECU? Please say orange EDIT I see the blue one in the pic
Re: Vaccum Diagram Needed [Re: RapidRobert] #613850
02/16/10 08:29 PM
02/16/10 08:29 PM
Burbank Ca
bkilby Offline OP
bkilby  Offline OP
Burbank Ca
Yeah, it was a light blue and is now replaced with a Standard Ignition dark blue. I'd rather have the Mopar box but I don't know where to buy them yet. Are they still available?
Re: Vaccum Diagram Needed [Re: bkilby] #613851
02/16/10 09:06 PM
02/16/10 09:06 PM
The oe black one w the yellow lettering? "Joesixpack" on here has alot of NOS stuff
