Disc brake spindle identification? #613811
02/15/10 01:21 AM
02/15/10 01:21 AM
Missouri
MOBodyman Offline OP
Missouri
I have a pair of disc brake spindles that I found in the trunk of a car I bought. Can they be identified by casting numbers? Some numbers are hard to read but this should be pretty close.
G18SLH2636274263
F H6 242643284
TIA,
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Disc brake spindle identification? [Re: MOBodyman] #613812
02/17/10 12:29 AM
02/17/10 12:29 AM
Missouri
Missouri
Any other way to identify them other than the casting numbers?
Thanks,
Dallas
Re: Disc brake spindle identification? [Re: MOBodyman] #613813
02/17/10 12:32 AM
02/17/10 12:32 AM
A pic is (always) worth a thousand words. Also dimentions (C to C on the spindle holes) and length of the tapered horizontle spindle could possibly help us ID it.
Re: Disc brake spindle identification? [Re: RapidRobert] #613814
02/18/10 03:58 AM
02/18/10 03:58 AM
Missouri
Missouri
Oops, I measured from the top of the upper ball joint mounting surface to the bottom of the lower ball joint mounting surface. It's right at 9". Sorry for the bad pic. The ruler covers the area and the pic is upside down.
Dallas
Re: Disc brake spindle identification? [Re: MOBodyman] #613815
02/18/10 04:23 AM
02/18/10 04:23 AM
Missouri
Missouri
The distance between the ball joint mounting surfaces is 6", outside to outside is 9".
The length of the stub where the wheel bearings go is 4 1/2" from the back of the mounting surface for the inner bearing to the outer tip of the threads.
Thanks,
Dallas
Re: Disc brake spindle identification? [Re: MOBodyman] #613816
02/18/10 07:31 PM
02/18/10 07:31 PM
BDW Offline
BDW  Offline
Re: Disc brake spindle identification? [Re: BDW] #613817
02/19/10 12:27 AM
02/19/10 12:27 AM
Missouri
Missouri
Look here
http://www.moparaction.com/tech/archive/disc-main.html
Well, I can see my knuckles are made different as mine have the lower ball joint attaching point made onto it as opposed to being a separate piece as shown in the article.
Here's another pic.
Dallas
Re: Disc brake spindle identification? [Re: MOBodyman] #613818
02/19/10 12:37 AM
02/19/10 12:37 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I don't know what you have, but they are not Mopar.
Don't look like anything Chrysler Corporation used in the line of brakes on their cars.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Disc brake spindle identification? [Re: hemi71x] #613819
02/19/10 01:27 AM
02/19/10 01:27 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree. They sort of look GM to me.
Re: Disc brake spindle identification? [Re: autoxcuda] #613820
02/19/10 02:26 AM
02/19/10 02:26 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
What bolt pattern are the discs, that might help narrow it down some
Re: Disc brake spindle identification? [Re: autoxcuda] #613821
02/19/10 03:04 AM
02/19/10 03:04 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I was thinking the same thing, look like GM to me.
