Disc brake spindle identification?
#613811
02/15/10 01:21 AM
02/15/10 01:21 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
I have a pair of disc brake spindles that I found in the trunk of a car I bought. Can they be identified by casting numbers? Some numbers are hard to read but this should be pretty close. G18SLH2636274263 F H6 242643284 TIA, Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Disc brake spindle identification?
[Re: MOBodyman]
#613812
02/17/10 12:29 AM
02/17/10 12:29 AM
MOBodyman
Missouri
Any other way to identify them other than the casting numbers? Thanks, Dallas
[Re: MOBodyman]
#613813
02/17/10 12:32 AM
02/17/10 12:32 AM
RapidRobert
A pic is (always) worth a thousand words. Also dimentions (C to C on the spindle holes) and length of the tapered horizontle spindle could possibly help us ID it.
[Re: RapidRobert]
#613814
02/18/10 03:58 AM
02/18/10 03:58 AM
MOBodyman
Missouri
Oops, I measured from the top of the upper ball joint mounting surface to the bottom of the lower ball joint mounting surface. It's right at 9". Sorry for the bad pic. The ruler covers the area and the pic is upside down. Dallas
[Re: MOBodyman]
#613815
02/18/10 04:23 AM
02/18/10 04:23 AM
MOBodyman
Missouri
The distance between the ball joint mounting surfaces is 6", outside to outside is 9". The length of the stub where the wheel bearings go is 4 1/2" from the back of the mounting surface for the inner bearing to the outer tip of the threads. Thanks, Dallas
[Re: MOBodyman]
#613816
02/18/10 07:31 PM
02/18/10 07:31 PM
Posts: 4,739 Florida
BDW
[Re: hemi71x]
#613819
02/19/10 01:27 AM
02/19/10 01:27 AM
Posts: 27,470 So Cal
autoxcuda
So Cal
I don't know what you have, but they are not Mopar. Don't look like anything Chrysler Corporation used in the line of brakes on their cars.
I agree. They sort of look GM to me.
