clutch fan died #613296
02/14/10 01:51 PM
02/14/10 01:51 PM
Connecticut
FurryStump Offline OP
Connecticut
Does anyone know the new number for the clutch fan. The car is a 68 barracuda 340-s auto ac. Rock auto shows a couple and the number on the original isn't one of them B0775SC. It is a themal one. Thanks
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: clutch fan died [Re: FurryStump] #613297
02/14/10 02:54 PM
02/14/10 02:54 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I believe the direct replacements are no longer available and the replacement numbers are actually taller and may not fit behind all radiators
https://board.moparts.org/ubbthreads/showflat.php?Number=5191061&page=0
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: clutch fan died [Re: HealthServices] #613298
02/14/10 03:36 PM
02/14/10 03:36 PM
Andrewh Online content
Andrewh  Online Content
replace the wp too while you are at it.
lost a rad because I didn't know.
the vibration caused by the clutch going out, hurt the bearing on the wp and I lost it a few months later.
Re: clutch fan died [Re: Andrewh] #613299
02/14/10 03:55 PM
02/14/10 03:55 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The lowest profile ones they make are a jaguar application. I can't recall the part number off the top of my head, but a search on here should reveal the one you want since it's been brought up a bunch over the years.
Check the wp as mentioned.
Re: clutch fan died [Re: Andrewh] #613300
02/14/10 05:15 PM
02/14/10 05:15 PM
Connecticut
Connecticut
Thanks for the replies. I found one that I could compare to the old one at advanced auto. It is about 3/8" shorter than the stock one. So it moves the fan that distance away from the radiator. It came with a bushing that adapts the center stub to fit. It is a heavy duty one, and the dia of the unit is bigger than the stock one but fit the original fan fine. It ends up with the fan about 5/8" from my three groove AC damper pulley. Made by Imperial/Hayden part number 215046.
Re: clutch fan died [Re: FurryStump] #613301
02/15/10 01:03 PM
02/15/10 01:03 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Hayden Part # 2765
Shortest I know of.
Tell the counter person that number, if need be, they can cross it over to their part number.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: clutch fan died [Re: Junky] #613302
02/15/10 07:51 PM
02/15/10 07:51 PM
Connecticut
Connecticut
Thanks for the reply. The one I got above is about as short as I could go. The fan is only about 5/8" from my three groove crank pully.
Re: clutch fan died [Re: FurryStump] #613303
02/16/10 12:31 AM
02/16/10 12:31 AM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I always just order up the kit from Mopar Performance.
Re: clutch fan died [Re: boydsdodge] #613304
02/16/10 08:01 AM
02/16/10 08:01 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I had 1 from advanced auto several years ago, on a chevy truck. The clutch itself broke off the shaft, and the fan screwed itself into the radiator. It was about 2 months old and I had to get real ugly with the manager to get a replacement radator that also came from them. I put a flex fan on it from them and it came apart also. It choped the heater hose clean in half as it flung of into the wild blue yonder. I do not buy thinks that have a safety issue from advanced any more.
Re: clutch fan died [Re: sbhpcb] #613305
02/16/10 07:17 PM
02/16/10 07:17 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
the short Jag clutch was for early BB b-bodies, IIRC. On my 68 360 b'cuda I used the 5 blade fan and clutch out of a late 80's, early 90's full size van. when used with the early water pump, it puts the fan exactly half in/ half out of the shroud.
if you still have the OEM unit that failed, save it, there is a rebuild service out there.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: clutch fan died [Re: GO_Fish] #613306
02/17/10 06:31 PM
02/17/10 06:31 PM
Connecticut
Connecticut
I still have the original one, I keep every original part that I have replace in a bin.
