Re: clutch fan died
[Re: FurryStump]
#613297
02/14/10 02:54 PM
02/14/10 02:54 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I believe the direct replacements are no longer available and the replacement numbers are actually taller and may not fit behind all radiators https://board.moparts.org/ubbthreads/showflat.php?Number=5191061&page=0
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: clutch fan died
[Re: sbhpcb]
#613305
02/16/10 07:17 PM
02/16/10 07:17 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
the short Jag clutch was for early BB b-bodies, IIRC. On my 68 360 b'cuda I used the 5 blade fan and clutch out of a late 80's, early 90's full size van. when used with the early water pump, it puts the fan exactly half in/ half out of the shroud.
if you still have the OEM unit that failed, save it, there is a rebuild service out there.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
