TO LIMIT THE UPPER CONTROLL ARMS OR NOT?
#610293
02/11/10 02:12 AM
02/11/10 02:12 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I Pulled apart and rebuilt the front suspension in my 68 dart. Its only a drag car and working on getting into the bottom 10 area. has stock A arm limiters or bumpers. What changes if any by adding taller limiters and would it hurt or help with 60 foot times? Thanks!! ![](/ubbthreads/images/graemlins/drive.gif)
Founder and CEO of the Central Valley Mopar Drag Pack
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT?
[Re: mikeysmopars]
#610295
02/11/10 06:55 AM
02/11/10 06:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Depends on alot of stuff, like Cab said... but are you hooking now, whats the rear suspension, what shocks all around, whats the power...... need more info ![](/ubbthreads/images/graemlins/wave.gif)
[Re: mikeysmopars]
#610297
02/12/10 10:50 AM
02/12/10 10:50 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
The only thing changed on my suspension is the '73-up front disc swap with 90/10 CE shocks and stock control arm stops. In the rear is S/S springs and QA-1 12 way adjustable shocks. If you don't have a lot of rear seperation (Cal Trac's, Ladder Bar, 4 Link) then you don't need as much front travel. Also limiting front end travel can have an effect on your RT. I try to keep mine in the beams as long as possible ![](/ubbthreads/images/graemlins/biggrin.gif)
