TO LIMIT THE UPPER CONTROLL ARMS OR NOT? #610293
02/11/10 02:12 AM
02/11/10 02:12 AM
fresno ca
mikeysmopars Offline OP
fresno ca
I Pulled apart and rebuilt the front suspension in my 68 dart. Its only a drag car and working on getting into the bottom 10 area. has stock A arm limiters or bumpers. What changes if any by adding taller limiters and would it hurt or help with 60 foot times?
Thanks!!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT? [Re: mikeysmopars] #610294
02/11/10 02:50 AM
02/11/10 02:50 AM
What type rear suspension? Trans brake or no? I have found that you will have to try limiting the up travel and the front ride hieght, torsion bar adjustments(total up travel, lower bumper hieghts) and type and adjustment of the front shocksto find out what your car likes. Some cars need different settings on different tracks for the best perforamnce
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT? [Re: mikeysmopars] #610295
02/11/10 06:55 AM
02/11/10 06:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends on alot of stuff, like Cab said... but are you
hooking now, whats the rear suspension, what shocks
all around, whats the power...... need more info
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT? [Re: mikeysmopars] #610296
02/11/10 09:25 AM
02/11/10 09:25 AM
NC
440Jim Offline
440Jim  Offline
NC
I put spacers under the stock upper A-arm bumpers to limit front end travel, when needed. I have a pair in various thicknesses:
0.080"
0.125"
0.187"
0.250"
I have used combinations up to 0.455" thick. They are basically large diameter (1.25-1.50") flat washers with a 3/8" hole.
If you put too much travel restriction in, it may spin the tires due to insufficient weight transfer. Combo dependant.
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT? [Re: mikeysmopars] #610297
02/12/10 10:50 AM
02/12/10 10:50 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The only thing changed on my suspension is the '73-up front disc swap with 90/10 CE shocks and stock control arm stops.
In the rear is S/S springs and QA-1 12 way adjustable shocks.
If you don't have a lot of rear seperation (Cal Trac's, Ladder Bar, 4 Link) then you don't need as much front travel.
Also limiting front end travel can have an effect on your RT. I try to keep mine in the beams as long as possible
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT? [Re: roadhazard] #610298
02/12/10 01:57 PM
02/12/10 01:57 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Mine likes stock travel and stock bumpers with worn out stock shocks....funny thing is I've had 3 sets of pricey shocks on the front.....yet I go back to the old Monroes....go figure...
Re: TO LIMIT THE UPPER CONTROLL ARMS OR NOT? [Re: Chassisman] #610299
02/12/10 02:05 PM
02/12/10 02:05 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
every car can be a little different, but a general rule of thumb is that with leaf spring rear suspension most cars like to have about 5 inches of upward travel on the front of the car to help with weight transfer.
I usually only limit front end travel to control wheel stands. Less front travel will usually produce less of a wheelie. Again, it can vary with different setups.
Scott
