Re: what is it called???
[Re: BlakDak]
#60800
05/21/08 09:03 AM
05/21/08 09:03 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
distribution block?
That's what I thought but I can not find any parts store (online) that carries it. Lines, brakes, P-valves, rebuild kits no problem. Any ideas who might stock them?
[Re: Mr.Yuck]
#60801
05/21/08 10:36 AM
05/21/08 10:36 AM
[Re: Moonraker]
#60804
05/21/08 10:41 AM
05/21/08 10:41 AM
How about proportioning valve
If it is at the front, going to the rear brake tee, then yes, it is the prop valve.
[Re: Mr.Yuck]
#60806
05/21/08 10:51 AM
05/21/08 10:51 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
It's not a P-Valve. It just transisions the hard line to the rubber line that attaches to the rear splitter/distribution valve.
the rear line connects directly to the rubber line , there is no transition block
[Re: Mr.Yuck]
#60808
05/21/08 10:55 AM
05/21/08 10:55 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
My rear rubber hose came with it attached if I get what your saying. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) 72 Swinger rear brake house from Raybestos
Ride eternal, shiny and chrome
[Re: Mr.Yuck]
#60809
05/21/08 10:57 AM
05/21/08 10:57 AM
JohnRR
this is kinda what I need. Is it part of the factory line? If it is none of the pictures show it. They all are just straight hoses.
i thought the rubber line just plug into the bracket and then a clip . which should have come with the line , held it in place ?
[Re: Mr.Yuck]
#60810
05/21/08 10:59 AM
05/21/08 10:59 AM
Chrysler sells a "lock" that holds the brake line in place, is that what it is? I will go out and look at one here.
[Re: Mr.Yuck]
#60812
05/21/08 11:09 AM
05/21/08 11:09 AM
Posts: 70,126 Here
DirectSubjection
Here
Isn't that square the retaining clip?
[Re: DirectSubjection]
#60814
05/21/08 11:23 AM
05/21/08 11:23 AM
I found some brackets that came with brake lines from Chrysler. Would this work, or is it what you need? ![](http://i303.photobucket.com/albums/nn133/krisiesmopes/DSCN4416.jpg)
#60816
05/21/08 11:45 AM
05/21/08 11:45 AM
"Just looked under the back of the Duster - the bracket is part of the car, non-removable and the retaining clip is one of those C-style ones - no square. Maybe bolt something like the one shown above on there?"
Pretty sure these were from 70's truck lines. The parts book shows the car one as a non-serviced part, maybe yours is broken off. If you could make these work, I would give them to you if you could cover the postage.
