what is it called??? #60798
05/21/08 08:39 AM
05/21/08 08:39 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
trying to get the brakes set up in my 70. What is the name of the part that the main brake line from the front attachs to and the rubber line then goes to the splitter on the rear? Rear brake block?
Re: what is it called??? [Re: Mr.Yuck] #60799
05/21/08 08:58 AM
05/21/08 08:58 AM
a cornfield near you
BlakDak Offline
BlakDak  Offline
distribution block?
Re: what is it called??? [Re: BlakDak] #60800
05/21/08 09:03 AM
05/21/08 09:03 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
distribution block?
That's what I thought but I can not find any parts store (online) that carries it. Lines, brakes, P-valves, rebuild kits no problem. Any ideas who might stock them?
Re: what is it called??? [Re: Mr.Yuck] #60801
05/21/08 10:36 AM
05/21/08 10:36 AM
Try rear brake tee.
Re: what is it called??? [Re: Mr.Yuck] #60802
05/21/08 10:39 AM
05/21/08 10:39 AM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
How about proportioning valve
Re: what is it called??? [Re: Mr.Yuck] #60803
05/21/08 10:40 AM
05/21/08 10:40 AM
Slidell, LA
Ronnman Online content
Ronnman  Online Content
Slidell, LA
Try Inline tube.
Ron
http://www.inlinetube.com/
Re: what is it called??? [Re: Moonraker] #60804
05/21/08 10:41 AM
05/21/08 10:41 AM
If it is at the front, going to the rear brake tee, then yes, it is the prop valve.
Re: what is it called??? #60805
05/21/08 10:47 AM
05/21/08 10:47 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
It's not a P-Valve. It just transisions the hard line to the rubber line that attaches to the rear splitter/distribution valve.
Re: what is it called??? [Re: Mr.Yuck] #60806
05/21/08 10:51 AM
05/21/08 10:51 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the rear line connects directly to the rubber line , there is no transition block
Re: what is it called??? [Re: Mr.Yuck] #60807
05/21/08 10:53 AM
05/21/08 10:53 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
this is kinda what I need. Is it part of the factory line? If it is none of the pictures show it. They all are just straight hoses.
Re: what is it called??? [Re: Mr.Yuck] #60808
05/21/08 10:55 AM
05/21/08 10:55 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
My rear rubber hose came with it attached if I get what your saying.
72 Swinger rear brake house from Raybestos
Ride eternal, shiny and chrome
Re: what is it called??? [Re: Mr.Yuck] #60809
05/21/08 10:57 AM
05/21/08 10:57 AM
JohnRR Offline
JohnRR  Offline
i thought the rubber line just plug into the bracket and then a clip . which should have come with the line , held it in place ?
Re: what is it called??? [Re: Mr.Yuck] #60810
05/21/08 10:59 AM
05/21/08 10:59 AM
Chrysler sells a "lock" that holds the brake line in place, is that what it is? I will go out and look at one here.
Re: what is it called??? #60811
05/21/08 11:07 AM
05/21/08 11:07 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yeah, I searched a bunch of stores online, including fine lines and none of the pictures shows the bracket attatched. And yes I believe it is held in by a clip.
Re: what is it called??? [Re: Mr.Yuck] #60812
05/21/08 11:09 AM
05/21/08 11:09 AM
Here
Here
Isn't that square the retaining clip?
Re: what is it called??? [Re: DirectSubjection] #60813
05/21/08 11:22 AM
05/21/08 11:22 AM
JohnRR Offline
JohnRR  Offline
i don't remember seeing that square on the line on my car ??
but then again it's been a long time since i swapped one of those
Re: what is it called??? [Re: DirectSubjection] #60814
05/21/08 11:23 AM
05/21/08 11:23 AM
I found some brackets that came with brake lines from Chrysler. Would this work, or is it what you need?
Re: what is it called??? [Re: JohnRR] #60815
05/21/08 11:38 AM
05/21/08 11:38 AM
Here
Here
Just looked under the back of the Duster - the bracket is part of the car, non-removable and the retaining clip is one of those C-style ones - no square. Maybe bolt something like the one shown above on there?
Re: what is it called??? [Re: DirectSubjection] #60816
05/21/08 11:45 AM
05/21/08 11:45 AM
"Just looked under the back of the Duster - the bracket is part of the car, non-removable and the retaining clip is one of those C-style ones - no square. Maybe bolt something like the one shown above on there?"
Pretty sure these were from 70's truck lines. The parts book shows the car one as a non-serviced part, maybe yours is broken off. If you could make these work, I would give them to you if you could cover the postage.
