Seen many OEM 440 blocks with lifter bore issues? #601760
02/02/10 05:12 PM
02/02/10 05:12 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
How many OEM 440 blocks have you encountered with significant lifter bore issues? As in either lifter bore alignment or bore sizing issues bad enough to require bushings?
As many of the engines were on the road for thousands of miles, I'd think that wouldn't be a frequent problem. However, considering the difference in how critical lifter-to-cam alignment is with more radical lobes, have I been blissfully ignorant?
FWIW, one of my blocks has the lifter bores bushed. But that was what my former engine builder did when the lifter bores were scored so badly after I wiped a cam big-time from too much spring pressure... when he selected the springs... and ran about 40#s more open pressure than the cam grinder specified. But that's a story for another time...
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: BradH] #601761
02/02/10 05:38 PM
02/02/10 05:38 PM
All of the stock Mopar, regardless of type, SB, BB or Hemi, have been big. 002+. One SB had a issue on one lifter bore alignment(slighly we think), which was found out after wiping out the same lobe twice in 50,000 miles It doesn't hurt to mock up the block and lifters your going to use before deciding if it needs fixing or not
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: Cab_Burge] #601762
02/02/10 05:49 PM
02/02/10 05:49 PM
BradH Offline OP
BradH  Offline OP
It would be cool if there was some trick tool / fixture that could be inserted into each lifter bore and "rolled" up against the respective cam lobe to check the tracking pattern, etc.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: BradH] #601763
02/02/10 07:08 PM
02/02/10 07:08 PM
okla.
sam64 Offline
sam64  Offline
okla.
or the famous only 1 oversize lifter from ma mopar,will sure screw things up.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: BradH] #601764
02/02/10 08:21 PM
02/02/10 08:21 PM
wappinger falls new york
Jimi_Vignogna Offline
i have lifter bore bushed 100's of big and small block mopar blocks, they all have horrible machining from ma mopar, any thing that is more than a street car rebuild should have it done.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: Jimi_Vignogna] #601765
02/02/10 08:48 PM
02/02/10 08:48 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
I'am not being a smart a$$ but I call BS.When you bush them all your doing is making them all the same size.The angle is not going to change.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: Jimi_Vignogna] #601766
02/02/10 08:59 PM
02/02/10 08:59 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I WILL NOT run a factory block without bushing the lifter bores.
Think about it this way. You can have the most accurate cam in the world only to screw up the timing events between the valve and piston position in the cylinder.
Degree every lobe in a production block and chart it. Then take the same cam and degree every lobe in a block that has been properly bushed and
Why bother with a indexed crank if you don't index the lifter to the cam
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: roadhazard] #601767
02/02/10 09:13 PM
02/02/10 09:13 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Whats the procedure for doing this? How to check? and how to fix/bush?
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: 8secDart] #601768
02/02/10 09:53 PM
02/02/10 09:53 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
I have bushed hundreds of them all. I can plot the bore locations with the renishaw probe and show you just how bad they are. I can plot the locations of both the top and bottom of the bore and calculate the error in the angle. As Jimi says, they are all horrible. What most fail to consider is that with the current crop of fast rate of lift flat tappet cams putting the lobe out right to the edge of the lifter, the block geometry has to be as precise as the cam is ground. Ma Mopar was the WORST of the big three as far as factory machining.
Now imagine how many flat tappet failures have been blamed on the cam and or lifters when the block is really the culprit. I laugh when I'm at COMP cams looking at how accurate the cams are ground knowing they'll be put in some 40yr old POS block And if you think stuffing a roller in is the fix, think about how moving the bore .020 from the center line and changing the angle of the lifter 1 degree affects valve timing events Now imagine having 16 different variations of that and look at the incremental power you are leaving on the table.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: 8secDart] #601769
02/02/10 09:58 PM
02/02/10 09:58 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
We correct the location of each bore on the camshaft centerline, the distance from the lead lifter to the cam thrust face after trueing the cam thrust face to be perpindicular to the crank centerline, the lifter bore to lifter bore spacing, and the angularity of all the lifter bores. If you just stuff bushing in the same hole or bore a block with the new bore in the same location as the old bore you're doing it wrong.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: CRE2004] #601770
02/02/10 10:03 PM
02/02/10 10:03 PM
8secDart Offline
8secDart  Offline
I stand corrected.I have bushed my Hemi stuff because of the money I had in them.NO $hit I have never had a wedge bushed and that is a lot of wedges.I know what you guys are saying about cam timing But at 8,000rpms that all goes out the window.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: CRE2004] #601771
02/02/10 10:05 PM
02/02/10 10:05 PM
Kewaskum, WI
K
Kelob_pie Offline
Kelob_pie  Offline
K
Kewaskum, WI
Yes, what Mike said.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: 8secDart] #601772
02/02/10 10:06 PM
02/02/10 10:06 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Maybe with a 3" base circle and 1" diameter pushrods we could kill the flex at 8g's
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: sam64] #601773
02/02/10 10:07 PM
02/02/10 10:07 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
sam64, how about all 16 holes being oversize and not realizing it. Couldn't figure at all why so little oil pressure!!!! Standard size lifter in .008 oversize hole is equal to a 1/2 inch hole in the oil system.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: CRE2004] #601774
02/02/10 10:45 PM
02/02/10 10:45 PM
8secDart Offline
8secDart  Offline
Maybe with a 3" base circle and 1" diameter pushrods we could kill the flex at 8g's [/quo
That would be great.LOL
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: CRE2004] #601775
02/02/10 10:59 PM
02/02/10 10:59 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
CRE2004 Thank you for taking the time!
Exactly what I was trying to say and then some AHMEN!
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: 8secDart] #601776
02/02/10 11:14 PM
02/02/10 11:14 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
No it makes it MORE IMPORTANT.
Does your rotating assembly balance go out the window at 8,000 rpm's
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: 8secDart] #601777
02/02/10 11:34 PM
02/02/10 11:34 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im not either a smart a$$, but if the bushing you are pressing in is thick enough you can accually manipulate the angle slightly, and then finish true the bores after the accual desired angle is achieved couldnt you?
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: Moparnut426] #601778
02/02/10 11:45 PM
02/02/10 11:45 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
You could do it that way but any follow up work work such as replacing a damaged bushing in the future is pure guess work. By correcting the bore location and geometry up front, you can pull out the bad bushing, pop in new ones, hone and go.
Re: Seen many OEM 440 blocks with lifter bore issues? [Re: Moparnut426] #601779
02/02/10 11:48 PM
02/02/10 11:48 PM
8secDart Offline
8secDart  Offline
I think that is what CRE2004 said.I was thinking it was harder to do being the bushing is only .100 to .125 thick.But he knows a hell of a lot more about block work than me.
