Seen many OEM 440 blocks with lifter bore issues?
#601760
02/02/10 05:12 PM
02/02/10 05:12 PM
BradH
How many OEM 440 blocks have you encountered with significant lifter bore issues? As in either lifter bore alignment or bore sizing issues bad enough to require bushings? As many of the engines were on the road for thousands of miles, I'd think that wouldn't be a frequent problem. However, considering the difference in how critical lifter-to-cam alignment is with more radical lobes, have I been blissfully ignorant? FWIW, one of my blocks has the lifter bores bushed. But that was what my former engine builder did when the lifter bores were scored so badly after I wiped a cam big-time from too much spring pressure... when he selected the springs... and ran about 40#s more open pressure than the cam grinder specified. But that's a story for another time...
Re: Seen many OEM 440 blocks with lifter bore issues?
[Re: BradH]
#601761
02/02/10 05:38 PM
02/02/10 05:38 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
All of the stock Mopar, regardless of type, SB, BB or Hemi, have been big. 002+. One SB had a issue on one lifter bore alignment(slighly we think), which was found out after wiping out the same lobe twice in 50,000 miles It doesn't hurt to mock up the block and lifters your going to use before deciding if it needs fixing or not
[Re: Jimi_Vignogna]
#601766
02/02/10 08:59 PM
02/02/10 08:59 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
i have lifter bore bushed 100's of big and small block mopar blocks, they all have horrible machining from ma mopar, any thing that is more than a street car rebuild should have it done.
I WILL NOT run a factory block without bushing the lifter bores.
Think about it this way. You can have the most accurate cam in the world only to screw up the timing events between the valve and piston position in the cylinder.
Degree every lobe in a production block and chart it. Then take the same cam and degree every lobe in a block that has been properly bushed and
Why bother with a indexed crank if you don't index the lifter to the cam
[Re: 8secDart]
#601768
02/02/10 09:53 PM
02/02/10 09:53 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
I'am not being a smart a$$ but I call BS.When you bush them all your doing is making them all the same size.The angle is not going to change.
I have bushed hundreds of them all. I can plot the bore locations with the renishaw probe and show you just how bad they are. I can plot the locations of both the top and bottom of the bore and calculate the error in the angle. As Jimi says, they are all horrible. What most fail to consider is that with the current crop of fast rate of lift flat tappet cams putting the lobe out right to the edge of the lifter, the block geometry has to be as precise as the cam is ground. Ma Mopar was the WORST of the big three as far as factory machining. Now imagine how many flat tappet failures have been blamed on the cam and or lifters when the block is really the culprit. I laugh when I'm at COMP cams looking at how accurate the cams are ground knowing they'll be put in some 40yr old POS block And if you think stuffing a roller in is the fix, think about how moving the bore .020 from the center line and changing the angle of the lifter 1 degree affects valve timing events Now imagine having 16 different variations of that and look at the incremental power you are leaving on the table.
[Re: 8secDart]
#601769
02/02/10 09:58 PM
02/02/10 09:58 PM
CRE2004
super gas
super gas
Illinois
We correct the location of each bore on the camshaft centerline, the distance from the lead lifter to the cam thrust face after trueing the cam thrust face to be perpindicular to the crank centerline, the lifter bore to lifter bore spacing, and the angularity of all the lifter bores. If you just stuff bushing in the same hole or bore a block with the new bore in the same location as the old bore you're doing it wrong.
[Re: 8secDart]
#601772
02/02/10 10:06 PM
02/02/10 10:06 PM
CRE2004
super gas
super gas
Illinois
I stand corrected.I have bushed my Hemi stuff because of the money I had in them.NO $hit I have never had a wedge bushed and that is a lot of wedges.I know what you guys are saying about cam timing But at 8,000rpms that all goes out the window.
Maybe with a 3" base circle and 1" diameter pushrods we could kill the flex at 8g's
[Re: CRE2004]
#601774
02/02/10 10:45 PM
02/02/10 10:45 PM
Posts: 1,256 Salisbury North Carolina
8secDart
Maybe with a 3" base circle and 1" diameter pushrods we could kill the flex at 8g's [/quo
That would be great.LOL
[Re: CRE2004]
#601775
02/02/10 10:59 PM
02/02/10 10:59 PM
roadhazard
Akron, Ohio U.S.A.
CRE2004 Thank you for taking the time!
Exactly what I was trying to say and then some AHMEN!
[Re: 8secDart]
#601776
02/02/10 11:14 PM
02/02/10 11:14 PM
roadhazard
Akron, Ohio U.S.A.
No it makes it MORE IMPORTANT. Does your rotating assembly balance go out the window at 8,000 rpm's
[Re: 8secDart]
#601777
02/02/10 11:34 PM
02/02/10 11:34 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Im not either a smart a$$, but if the bushing you are pressing in is thick enough you can accually manipulate the angle slightly, and then finish true the bores after the accual desired angle is achieved couldnt you?
[Re: Moparnut426]
#601778
02/02/10 11:45 PM
02/02/10 11:45 PM
CRE2004
super gas
super gas
Illinois
You could do it that way but any follow up work work such as replacing a damaged bushing in the future is pure guess work. By correcting the bore location and geometry up front, you can pull out the bad bushing, pop in new ones, hone and go.
