Advice on making my own honing plate B/RB and HEMI #600811
02/01/10 04:56 PM
02/01/10 04:56 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I want to make my own honing plate for B/RB and HEMI engines.
I was looking for some advice here.
1. How thick does it need to be? Any other special considerations?
2. Is it possible to make the plate work for both HEMI and B/RB bolt patterns. I think the only difference is the 5th bolt hole towards the lifter valley, but I think it overlaps, so It cant be drilled for the dual pattern. Instead I was thinking of flipping the plate and drilling it for the HEMI pattern because I thinik the holes wont overlap that way. Has anybody done it like that? Does it work?
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600812
02/01/10 05:04 PM
02/01/10 05:04 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Get a head gasket for each motor, lay one over the other, and see what you get. Buddy of mine that makes torque plates usually makes them 2" thick, head gasket gives you the hole pattern, depth of the holes is cut to duplicate shape of the head and the clamping load on the block.
It's not as easy as it sounds. Contact CJ @ cj@yother.com or at 510-865-2787, he may have one in stock.
Post deleted by Defbob [Re: domingo] #600813
02/01/10 05:12 PM
02/01/10 05:12 PM
Re: Advice on making my own honing plate B/RB and HEMI #600814
02/01/10 06:32 PM
02/01/10 06:32 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Been there/done that...a whole lot simplier to buy a plate!!!! The time spent making one is way more than you anticipate.
If you like drag racing, support your local track.
Re: Advice on making my own honing plate B/RB and HEMI [Re: CHAPPER] #600815
02/01/10 06:46 PM
02/01/10 06:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There are going to be some naysayers about this, however ...
Since a torque plate is there to duplicate the stresses applied by the bolts, simply making one out of 2" plate isn't the solution. The plate needs to be milled to accept the shorter bolts on the exhaust side.
If you're going to do it, water-jetting the bores would likely be the cheapest route and they don't need to be accurately sized, anything larger than the bore you're working with will do.
Now then... As previously stated, its the stresses of the bolts you want to duplicate so ... get a length of 7/16" or 1/2" i.d. DOM tubing with as thick of a wall as can be used without overhanging the bores. Cut lengths equal to the head thickness at each bolt. Ideally they should be finished on a lathe to ensure the ends are square so as not to improperly load the bolts. Make a complete set and torque these down. Voila, poor man's torque plate! Hone away!
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600816
02/01/10 07:10 PM
02/01/10 07:10 PM
Boise
Moparteacher Offline
Boise
I can tell you this...use a hemi plate on a wedge block and your cylinders won't come out round.
Re: Advice on making my own honing plate B/RB and HEMI #600817
02/01/10 09:46 PM
02/01/10 09:46 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Would it be easier to just buy a junk set of iron Hemi heads and mill the cylinder holes in them?
Cost of the junk head alone would be more than a honing plate, then you'd still have to poke the holes in it.
But then again, I just looked up what a aluminum honing plate for a hemi was and it was $790.00 Got a junk head and a hole saw?
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600818
02/02/10 02:08 AM
02/02/10 02:08 AM
AndyF Offline
AndyF  Offline
If you can't afford to buy a torque plate then just use head bolts (or studs) with the correct spacers under them. That is super cheap and will get you roughly the same result.
Re: Advice on making my own honing plate B/RB and HEMI [Re: AndyF] #600819
02/02/10 05:26 PM
02/02/10 05:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I can make my own plate. It's not rocket science.
I have a friend with a CNC.
Whats the bore spacing on a B/RB and HEMI? I am asking because I can draw the thing on the CNC, specify 4,6" bores and Im done. Ill drill the head bolt holes by hand on a bench drill using a gasket as a template. or if I can draw them on the PC the cnc will take care of the bolt pattern too.
I also checked with gasket and I can flip the plate and drill both the hemi and RB bolt pattern using the same plate....Ill just have to flip it for RB and then again flip it for HEMI.
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600820
02/02/10 05:39 PM
02/02/10 05:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
17 1/2" holes through 2" plate on a drillpress... You're a better man than me !!!!
Re: Advice on making my own honing plate B/RB and HEMI [Re: Stanton] #600821
02/02/10 05:49 PM
02/02/10 05:49 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I've made two plates over the years. One for a RB and one for my TS engine. (hemi bolt pattern and 4.840bs)
The guy at the engine shop said he had none for mopars so a just made my own out of 2 inch mild steel. Cut the big wholes on a small milling machine and did all the bolt holes on a drill press.
The guy asked me if i would start making them for him cause he said he was paying 800-1000$ for plates.
Pretty easy to make if you have the time.
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600822
02/02/10 06:41 PM
02/02/10 06:41 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Keep in mind, the bolt pattern for the inner row of studs is angled on hemi blocks/heads.
Re: Advice on making my own honing plate B/RB and HEMI [Re: DoctorDiff] #600823
02/02/10 06:51 PM
02/02/10 06:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for that tip.
Whats the bore spacing on the HEMI and RB?
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600824
02/02/10 10:35 PM
02/02/10 10:35 PM
detroit area
moderncylinder Offline
detroit area
4.800 is the bore spacing,, i have a print that gives you dowel locations, bolt holes, cylinder bores,,, give me your email and ill try to send it in the next few days,, it will be an iges file
Re: Advice on making my own honing plate B/RB and HEMI [Re: moderncylinder] #600825
02/02/10 10:41 PM
02/02/10 10:41 PM
rowin4 Offline
rowin4  Offline
Jeff while your on here, how hard would it be to use a junk head for a plate?
Post deleted by Defbob [Re: rowin4] #600826
02/02/10 11:08 PM
02/02/10 11:08 PM
Re: Advice on making my own honing plate B/RB and HEMI #600827
02/02/10 11:39 PM
02/02/10 11:39 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
I already asked that, I'd like to know also. Seems like it would produce real world distortions in the block. The ideal situation would be to run hot water through the block while honing.
Cutting the bores out of a head changes the structural integrity of the head itself thereby changing the way it affects the bore distortion(not to mention cuts open the water jacket so out goes the hot honing theory). Using a torque plate will simulate the majority of the distortion, but adding the same head gasket as will be used in the final combo gets it as close as practical. From what I've experienced, using a cometic doesn't change it much, a composition with a fire ring acts like a fulcrum and changes things substantially. Just using the bolts and spacers with no plate would have little to no effect on anything.
Re: Advice on making my own honing plate B/RB and HEMI [Re: CRE2004] #600828
02/02/10 11:48 PM
02/02/10 11:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yeah, what the hell does Andy know !!!
Re: Advice on making my own honing plate B/RB and HEMI [Re: domingo] #600829
02/02/10 11:51 PM
02/02/10 11:51 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
just buy a used bhj hemi plate of ebay they pop up now and again cheap, unless your wicked machinist might do more harm than good
MOPAR OR NO CAR
Re: Advice on making my own honing plate B/RB and HEMI [Re: Stanton] #600830
02/02/10 11:54 PM
02/02/10 11:54 PM
rowin4 Offline
rowin4  Offline
When I read that post I didn't look who wrote it, thought that's not going to work, but then , I'm the one always
asking questions.
