Re: Advice on making my own honing plate B/RB and HEMI
[Re: domingo]
#600812
02/01/10 05:04 PM
02/01/10 05:04 PM
Posts: 20,847 A collage of whims
topside
A collage of whims
Get a head gasket for each motor, lay one over the other, and see what you get. Buddy of mine that makes torque plates usually makes them 2" thick, head gasket gives you the hole pattern, depth of the holes is cut to duplicate shape of the head and the clamping load on the block. It's not as easy as it sounds. Contact CJ @ cj@yother.com or at 510-865-2787, he may have one in stock.
Post deleted by Defbob
[Re: domingo]
#600813
02/01/10 05:12 PM
02/01/10 05:12 PM
#600814
02/01/10 06:32 PM
02/01/10 06:32 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Been there/done that...a whole lot simplier to buy a plate!!!! The time spent making one is way more than you anticipate.
If you like drag racing, support your local track.
[Re: CHAPPER]
#600815
02/01/10 06:46 PM
02/01/10 06:46 PM
Posts: 8,899 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
There are going to be some naysayers about this, however ...
Since a torque plate is there to duplicate the stresses applied by the bolts, simply making one out of 2" plate isn't the solution. The plate needs to be milled to accept the shorter bolts on the exhaust side.
If you're going to do it, water-jetting the bores would likely be the cheapest route and they don't need to be accurately sized, anything larger than the bore you're working with will do.
Now then... As previously stated, its the stresses of the bolts you want to duplicate so ... get a length of 7/16" or 1/2" i.d. DOM tubing with as thick of a wall as can be used without overhanging the bores. Cut lengths equal to the head thickness at each bolt. Ideally they should be finished on a lathe to ensure the ends are square so as not to improperly load the bolts. Make a complete set and torque these down. Voila, poor man's torque plate! Hone away!
[Re: domingo]
#600820
02/02/10 05:39 PM
02/02/10 05:39 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Ill drill the head bolt holes by hand on a bench drill using a gasket as a template.
17 1/2" holes through 2" plate on a drillpress... You're a better man than me !!!!
[Re: DoctorDiff]
#600823
02/02/10 06:51 PM
02/02/10 06:51 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Keep in mind, the bolt pattern for the inner row of studs is angled on hemi blocks/heads.
Thanks for that tip.
Whats the bore spacing on the HEMI and RB?
[Re: domingo]
#600824
02/02/10 10:35 PM
02/02/10 10:35 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
4.800 is the bore spacing,, i have a print that gives you dowel locations, bolt holes, cylinder bores,,, give me your email and ill try to send it in the next few days,, it will be an iges file
[Re: rowin4]
#600826
02/02/10 11:08 PM
02/02/10 11:08 PM
#600827
02/02/10 11:39 PM
02/02/10 11:39 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Jeff while your on here, how hard would it be to use a junk head for a plate?
I already asked that, I'd like to know also. Seems like it would produce real world distortions in the block. The ideal situation would be to run hot water through the block while honing.
Cutting the bores out of a head changes the structural integrity of the head itself thereby changing the way it affects the bore distortion(not to mention cuts open the water jacket so out goes the hot honing theory). Using a torque plate will simulate the majority of the distortion, but adding the same head gasket as will be used in the final combo gets it as close as practical. From what I've experienced, using a cometic doesn't change it much, a composition with a fire ring acts like a fulcrum and changes things substantially. Just using the bolts and spacers with no plate would have little to no effect on anything.
[Re: CRE2004]
#600828
02/02/10 11:48 PM
02/02/10 11:48 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Yeah, what the hell does Andy know !!!
[Re: Stanton]
#600830
02/02/10 11:54 PM
02/02/10 11:54 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
When I read that post I didn't look who wrote it, thought that's not going to work, but then , I'm the one always asking questions.
