Avenger key removal
#598495
01/30/10 04:20 PM
01/30/10 04:20 PM
Posts: 123 Elizabethton Tn
louie heaton
Elizabethton Tn
Have a 96 Avenger I use for a back up car... don't drive much,,, can't get the key out of the switch most of the time,,, if I drive more regularaly,, sometimes if I fiddle with the shifter, it will come out,,, does it have something like a neutral switch in the console , or linkage somewhere,, most of the time it wont come out,, stuck in the ACC position...???
70 T/A clone, Hensley built 440,(not much more than stock) Low 12's at Bristol,(17 miles from here)8 other various Mopars, used to have 800+ posts back around 2001.
Re: Avenger key removal
[Re: louie heaton]
#598496
01/30/10 07:14 PM
01/30/10 07:14 PM
Posts: 223 Poplar Bluff, Missouri
partfiler69
Still Wondering
Still Wondering
there is a cable that goes from the shifter to the steering column that is the problem. it is not extending the cable all the way. i had that problem on my old chebby, i just disconnected it from the column, worked fine after that.
Back from hiatus
[Re: partfiler69]
#598497
01/30/10 07:34 PM
01/30/10 07:34 PM
louie heaton
Elizabethton Tn
partfiller69, thanks,, that must be a long cable,, where would be the best place to discconect it ,,, the floor console or steering column,, not sure where to do it at the steering column,, there is not a lot of room in this mitsubishi built car..
[Re: rth]
#598500
01/30/10 08:31 PM
01/30/10 08:31 PM
louie heaton
Elizabethton Tn
Thanks, guys,,, will try in a couple of days...
