Have a 96 Avenger I use for a back up car... don't drive much,,, can't get the key out of the switch most of the time,,, if I drive more regularaly,, sometimes if I fiddle with the shifter, it will come out,,, does it have something like a neutral switch in the console , or linkage somewhere,, most of the time it wont come out,, stuck in the ACC position...???
70 T/A clone, Hensley built 440,(not much more than stock) Low 12's at Bristol,(17 miles from here)8 other various Mopars, used to have 800+ posts back around 2001.
