Can someone help me ID these transmissions?
#59748
05/19/08 02:40 PM
05/19/08 02:40 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
Would any of these fit a 340? I am looking for a 727-A and this guy has these for sale but isn't sure what they fit. He sent the photos.
Some people you just can't reach...
Re: Can someone help me ID these transmissions?
[Re: 375inStroke]
#59754
05/19/08 09:08 PM
05/19/08 09:08 PM
Suregrip
Fort Lauderdale, FL
I had the guy dig some more transmissions out, I think he has two 727-A trannys two photos of one, and one photo of the other. Here is another question; if a transmission was rebuilt and never used for say ten years can it be used or will it need to be gone through again. Thanks guys, Fred.
[Re: Suregrip]
#59755
05/19/08 09:11 PM
05/19/08 09:11 PM
Suregrip
Fort Lauderdale, FL
Another question; is a valve body exchangable between a 727-A and a 727-B? Also, is a valve body exchangable between a 904 and a 727-A or B? Thanks again, Fred.
[Re: Suregrip]
#59757
05/19/08 09:25 PM
05/19/08 09:25 PM
Suregrip
Fort Lauderdale, FL
John RR the trans is going behind a mild 73 340 in a 73 RR. You might remember me asking on the site if I should buy the car. I did. Fred.
[Re: Suregrip]
#59759
05/20/08 07:39 AM
05/20/08 07:39 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Last photo... of I believe an actual 727-A.
Fred , this to me looks like the trans from the first pic , its a cable shift 65 , not going to work for you . yes its a smallblock 727 but its not what you want to use .
there is a number stamped on the side of the transmission on the driver side at the pan rail , have the guy give you those numbers , no guessing as to what it MIGHT be .
your question on a 10 yr old rebuild thats been sitting , i would take it apart and check the seals , possibly reseal it , a gasket kit is cheap , but then again i have the tools and the past experience to freshen one .
[Re: 375inStroke]
#59761
05/20/08 07:43 AM
05/20/08 07:43 AM
JohnRR
U.S.S.A.
Slant six has the starter at about the 11 o'clock position, looking forward. Big block has it at about 9 o'clock, and small block at about 7 o'clock.
with this in mind those are looking like big block trannys other than the one obvious 6 banger trans
[Re: JohnRR]
#59762
05/20/08 10:07 AM
05/20/08 10:07 AM
Suregrip
Fort Lauderdale, FL
Thanks John, I will see if he can get me the numbers off the side of the pan rail. I take it that the 727-A and 727-B valve bodies inter-change with out mods?
[Re: Suregrip]
#59763
05/20/08 11:29 AM
05/20/08 11:29 AM
JohnRR
U.S.S.A.
yes they will , but depending on the application there might be a slight variance in shift timing .
