Can someone help me ID these transmissions? #59748
05/19/08 02:40 PM
05/19/08 02:40 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Would any of these fit a 340? I am looking for a 727-A and this guy has these for sale but isn't sure what they fit. He sent the photos.
Some people you just can't reach...
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59749
05/19/08 02:41 PM
05/19/08 02:41 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
another photos...
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59750
05/19/08 02:42 PM
05/19/08 02:42 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Last one, thanks, Fred.
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59751
05/19/08 02:44 PM
05/19/08 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there are 3 different transmissions in those pics ,
second one is a cable shift , flanged unit , not what you want
third picture is for a slant 6 so it won't fit .
can you get the guy to give you the number that is on the first one ? or atleast a shot of it from the end that bolts to the engine ?
Re: Can someone help me ID these transmissions? [Re: JohnRR] #59752
05/19/08 02:48 PM
05/19/08 02:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what car are you putting this in ? the top one also looks like an early rear pump trans , pre 66 ???? but with a slip yoke , so it would be a cable shift also , 65 ???
Re: Can someone help me ID these transmissions? [Re: JohnRR] #59753
05/19/08 08:05 PM
05/19/08 08:05 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Slant six has the starter at about the 11 o'clock position, looking forward. Big block has it at about 9 o'clock, and small block at about 7 o'clock.
Re: Can someone help me ID these transmissions? [Re: 375inStroke] #59754
05/19/08 09:08 PM
05/19/08 09:08 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
I had the guy dig some more transmissions out, I think he has two 727-A trannys two photos of one, and one photo of the other.
Here is another question; if a transmission was rebuilt and never used for say ten years can it be used or will it need to be gone through again. Thanks guys, Fred.
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59755
05/19/08 09:11 PM
05/19/08 09:11 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Another question; is a valve body exchangable between a 727-A and a 727-B? Also, is a valve body exchangable between a 904 and a 727-A or B? Thanks again, Fred.
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59756
05/19/08 09:12 PM
05/19/08 09:12 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Last photo... of I believe an actual 727-A.
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59757
05/19/08 09:25 PM
05/19/08 09:25 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
John RR the trans is going behind a mild 73 340 in a 73 RR. You might remember me asking on the site if I should buy the car. I did. Fred.
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59758
05/20/08 05:49 AM
05/20/08 05:49 AM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
More photos and questions...
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59759
05/20/08 07:39 AM
05/20/08 07:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Fred , this to me looks like the trans from the first pic , its a cable shift 65 , not going to work for you . yes its a smallblock 727 but its not what you want to use .
there is a number stamped on the side of the transmission on the driver side at the pan rail , have the guy give you those numbers , no guessing as to what it MIGHT be .
your question on a 10 yr old rebuild thats been sitting , i would take it apart and check the seals , possibly reseal it , a gasket kit is cheap , but then again i have the tools and the past experience to freshen one .
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59760
05/20/08 07:42 AM
05/20/08 07:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes they are exchangable , but to change a 727 into a 904 you have to modify the seperator plate as there is a hole that is offset , its like that for a reason so i wouldn't do something like that unless i was broken down on the side of the road in the middle of no where and had a pile of transmissions in the back of my truck ...
the picture attached to this quote is a big block trans ...
Re: Can someone help me ID these transmissions? [Re: 375inStroke] #59761
05/20/08 07:43 AM
05/20/08 07:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
with this in mind those are looking like big block trannys other than the one obvious 6 banger trans
Re: Can someone help me ID these transmissions? [Re: JohnRR] #59762
05/20/08 10:07 AM
05/20/08 10:07 AM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Thanks John, I will see if he can get me the numbers off the side of the pan rail. I take it that the 727-A and 727-B valve bodies inter-change with out mods?
Re: Can someone help me ID these transmissions? [Re: Suregrip] #59763
05/20/08 11:29 AM
05/20/08 11:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes they will , but depending on the application there might be a slight variance in shift timing .
