Big Block Oil Pump Priming Tool #595080
01/26/10 09:32 PM
01/26/10 09:32 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Do both ends have square drives? Or is one end shaped like the end of a distributor to fit the slot in the gear? Pic of both ends would be greatly appreciated.
Re: Big Block Oil Pump Priming Tool [Re: Kudakidd] #595081
01/26/10 09:38 PM
01/26/10 09:38 PM
RapidRobert Online content
RapidRobert  Online Content
5/16" hex like the end of the inter shaft. Got an old one-grind the teeth off & use a screwdriver bit
Re: Big Block Oil Pump Priming Tool [Re: Kudakidd] #595082
01/26/10 09:41 PM
01/26/10 09:41 PM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Both ends hexogon six sides
Re: Big Block Oil Pump Priming Tool [Re: Kudakidd] #595083
01/26/10 10:01 PM
01/26/10 10:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Find a pump drive shaft from a Ford, they're 5/16" hex for the entire length.
Re: Big Block Oil Pump Priming Tool [Re: John_Kunkel] #595084
01/27/10 12:22 AM
01/27/10 12:22 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
STILL waiting to have some steel and aluminum 5/16 hex stock PLASTIC COATED in the middle ...to prevent damage to the intermediate-shaft-bushing during usage. They should be available in a month or so ... the cost should be just slightly more than a plain-jane hex rod.
Re: Big Block Oil Pump Priming Tool [Re: BeEtLeJuIcE !] #595085
01/27/10 02:59 AM
01/27/10 02:59 AM
AndyF Offline
AndyF  Offline
I use an aluminum rod with a hex pressed into the end. I'm sure that several places make priming rods, probably easier for people to just order one than to make one.
Re: Big Block Oil Pump Priming Tool [Re: BeEtLeJuIcE !] #595086
01/27/10 03:17 AM
01/27/10 03:17 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Word!
I turned my shaft so it was round in the area of contact. Don't want to end up with brass shavings in the motor and a damaged bushing.
Re: Big Block Oil Pump Priming Tool [Re: Kudakidd] #595087
01/27/10 08:38 AM
01/27/10 08:38 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Buy a 5/16" solid rod and take 2 minutes and grind a hex on one end and your good for life. Cheaper than buying a paint stir or anything else. I made one 20 years ago out of a 5/16" piece of tubing. I've used it to prime about 50 hemis with 60 weight oil in em.
The one with yellow tape is my home made piece. It's hollow tubing, solid will work too.
Re: Big Block Oil Pump Priming Tool [Re: Kudakidd] #595088
01/27/10 11:08 AM
01/27/10 11:08 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
the gear has to come out
Re: Big Block Oil Pump Priming Tool [Re: bonefish] #595089
01/27/10 12:08 PM
01/27/10 12:08 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I actually found one when rebuilding a friends 340-6.
This is what I found after driving it to my place and pulling the intake
I took a picture of it as found, before taking it out.
Re: Big Block Oil Pump Priming Tool [Re: Finoke] #595090
01/27/10 12:08 PM
01/27/10 12:08 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Re: Big Block Oil Pump Priming Tool [Re: Finoke] #595091
01/27/10 12:14 PM
01/27/10 12:14 PM
Cincinnati, Ohio
Cincinnati, Ohio
arn't you a lucky guy, free tool!!
Re: Big Block Oil Pump Priming Tool [Re: Finoke] #595092
01/27/10 12:15 PM
01/27/10 12:15 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
wow. that is a really stupid mistake.
71 scamp big block with 915 heads 727 trans
Re: Big Block Oil Pump Priming Tool [Re: Challenger 1] #595093
01/27/10 12:43 PM
01/27/10 12:43 PM
x2
Re: Big Block Oil Pump Priming Tool [Re: RapidRobert] #595094
01/27/10 03:44 PM
01/27/10 03:44 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
x2
I love free tools
Been using it every since
