Re: Big Block Oil Pump Priming Tool
[Re: Kudakidd]
#595081
01/26/10 09:38 PM
01/26/10 09:38 PM
RapidRobert
5/16" hex like the end of the inter shaft. Got an old one-grind the teeth off & use a screwdriver bit
[Re: Kudakidd]
#595083
01/26/10 10:01 PM
01/26/10 10:01 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Find a pump drive shaft from a Ford, they're 5/16" hex for the entire length.
[Re: dOoC]
#595086
01/27/10 03:17 AM
01/27/10 03:17 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
STILL waiting to have some steel and aluminum 5/16 hex stock PLASTIC COATED in the middle ...to prevent damage to the intermediate-shaft-bushing during usage. They should be available in a month or so ... the cost should be just slightly more than a plain-jane hex rod.
Word!
I turned my shaft so it was round in the area of contact. Don't want to end up with brass shavings in the motor and a damaged bushing.
[Re: Kudakidd]
#595088
01/27/10 11:08 AM
01/27/10 11:08 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Do both ends have square drives? Or is one end shaped like the end of a distributor to fit the slot in the gear? Pic of both ends would be greatly appreciated.
the gear has to come out
[Re: bonefish]
#595089
01/27/10 12:08 PM
01/27/10 12:08 PM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
I actually found one when rebuilding a friends 340-6. This is what I found after driving it to my place and pulling the intake I took a picture of it as found, before taking it out.
[Re: RapidRobert]
#595094
01/27/10 03:44 PM
01/27/10 03:44 PM
Finoke
Horsham, Pa.
arn't you a lucky guy, free tool!!
x2
I love free tools
Been using it every since
