Carrier bearings - how to remove? #593964
01/25/10 08:34 PM
01/25/10 08:34 PM
PA
Y
yellowfin Offline OP
Y
PA
I have a clutch-style SG carrier that needs the bearings removed. Looking at the FSM, they picture a special tool needed to remove them, but there's no way I'm going that route - anyone have a simple way to get them off? I have already pulled off the cages and rollers on the one with a gear puller, but the inner race is still locked prety solid on the carrier. I was thinking about a little heat from a propane torch and some P-oil, but I don't want to ruin anything either. There is very little for any puller to get a hold of, as they were pressed all the way down to the base of the carrier flange. I was going to get a dull chisel and alternate blows all around after heating until it moved enough for my puller to get a hold of the lip. Any ideas?
Re: Carrier bearings - how to remove? [Re: yellowfin] #593965
01/25/10 08:47 PM
01/25/10 08:47 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Press to put on, and to take off.
You can cut a slot in the race and used a chisel to break the race, once the race has a crack in it, it will fall off, but once you get it off how are you expecting to install the new one?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Carrier bearings - how to remove? [Re: yellowfin] #593966
01/25/10 08:55 PM
01/25/10 08:55 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Here is a puller that works on 8-3/4 and Dana power loks (clutch)since the case has a puller groove machined behind the bearing. I don't know if the cone type has this groove. This is a Miller SPX tool.
Re: Carrier bearings - how to remove? [Re: 446acuda] #593967
01/25/10 09:02 PM
01/25/10 09:02 PM
So Cal
So Cal
You still need one of these with that tool
and it won't install the bearing either
Re: Carrier bearings - how to remove? [Re: 446acuda] #593968
01/25/10 09:03 PM
01/25/10 09:03 PM
PA
Y
Y
PA
My case has no puller groove behind the bearing race - it fits tight against the shoulder of the carrier. Mine is a spicer-type unit, I believe.
Re: Carrier bearings - how to remove? [Re: 446acuda] #593969
01/25/10 09:05 PM
01/25/10 09:05 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Split the old with a cutoff wheel and/or a chisel. Then it'll come off easy.
No press needed to install either.
Heat the bearing in a electric frying pan, and drop it on with a welding glove. Have a punch ready in case it hangs up, so you can give it a tap if needed.
Re: Carrier bearings - how to remove? [Re: HealthServices] #593970
01/25/10 09:08 PM
01/25/10 09:08 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
no you don't. That puller does the job without anything else. I've used it dozen of times. Installing the bearing is no issue. Using a hammer and the old inner race, big socket, piece of pipe etc will do that job.
Re: Carrier bearings - how to remove? [Re: dave571] #593971
01/25/10 09:10 PM
01/25/10 09:10 PM
So Cal
So Cal
Boy the things you forget when you have tools for just about everything.
Re: Carrier bearings - how to remove? [Re: 446acuda] #593972
01/25/10 09:42 PM
01/25/10 09:42 PM
PA
Y
Y
PA
So i'm stuck buying or borrowing one of these specialty tools to get my bearings off? I could try and chisel a groove and spit it open, but aren't they a tough steel to work with? A cutoff wheel would work a little better, but the chance of going too deep and scoring the carrier ends to me seems too much of a possibility. Could I mig weld two "perches" to the race and use them as something for my puller to grab hold of? Or is that still too much heat for the carrier?
Re: Carrier bearings - how to remove? [Re: yellowfin] #593973
01/25/10 09:59 PM
01/25/10 09:59 PM
So Cal
So Cal
If it is really a problem to remove I would try this, although it has been a while since I've gone to a NAPA or a mom or pop shop in a long time for press use but they normally charge very little ($15 or less) to pull and install bearings with their press. Otherwise carry it into a dealer and normally a tech can pull it off for you for a $10 or a $20 spot.
When making the cut with a cutoff wheel you do not have to make the cut perpendicular to the base of the race. You can cut a diagonal. A nick on the carrier should be ok just deburr it if you do.
Re: Carrier bearings - how to remove? [Re: yellowfin] #593974
01/25/10 10:21 PM
01/25/10 10:21 PM
dave571 Offline
dave571  Offline
Personally, I cut into the race with a cutoff wheel, then use a chisel in the cut to split it.
You won't score it if you're careful.
If you score the carrier, it is really not a big deal. The race doesn't spin on it, it is pressed on. A mark in it will not affect it. Just make sure it isn't burred or it'll stop the new one from going on properly. Touch it up with a few file strokes, and it should be fine.
You can try the welding thing, but the inner race is pretty hard stuff. I guess as long as the race comes off when you done, then you've done it right.
Re: Carrier bearings - how to remove? [Re: 446acuda] #593975
01/25/10 10:22 PM
01/25/10 10:22 PM
So Cal
So Cal
You did not read the op's first thread, he pulled off the cage and rollers, so there is no cage to grab onto anymore.
Depending on the interference fit I normally will not go banging on any bearings to install them.
Re: Carrier bearings - how to remove? [Re: dave571] #593976
01/25/10 10:38 PM
01/25/10 10:38 PM
PA
Y
Y
PA
Thanks guys - at least I have a few options to choose from now. I think I'll try the wheel/chisel first and if that doesn't do the trick, I'll weld some "ears" on each side and use that to pull it off with. Just a shame the factory couldn't have put a recess in there for a regular puller to work. Guess they thought that if it lasted 7-10 yrs or so it was good enough.
Re: Carrier bearings - how to remove? [Re: yellowfin] #593977
01/26/10 02:05 AM
01/26/10 02:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Re: Carrier bearings - how to remove? [Re: DoctorDiff] #593978
01/26/10 03:15 AM
01/26/10 03:15 AM
So Cal
So Cal
Wow, how does something like that work? Without instructions I would never of thought it removed bearings.
Re: Carrier bearings - how to remove? [Re: HealthServices] #593979
01/26/10 03:23 AM
01/26/10 03:23 AM
So Cal
So Cal
Sorry I could not wait. I have a small fetish for tools.
http://www.pirate4x4.com/tech/billavista/PR-ARB/articles/Randys_Carrier_Bearing_Puller_Review/
pretty badazz tool
Re: Carrier bearings - how to remove? [Re: HealthServices] #593980
01/26/10 06:53 AM
01/26/10 06:53 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Wrong again. That tool doesn't require that the bearing has a cage or rollers since it grabs the inner race so that the bearing can be reused like when setting diff bearing preload on a Dana.
Re: Carrier bearings - how to remove? [Re: DoctorDiff] #593981
01/26/10 07:00 AM
01/26/10 07:00 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
I have one of these:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250555400225
It works very well.
Best tool ever, if it's the same I'm thinking of you can do a ton of different bearing setups with it.
Re: Carrier bearings - how to remove? [Re: 446acuda] #593982
01/26/10 01:40 PM
01/26/10 01:40 PM
So Cal
So Cal
This is one of those things you would have to show me, without the cage and rollers your tool does not have a shoulder to grab onto.
your tool
similar tool in action with cage
Op mention not having a case that has a puller groove machined behind the bearing
Show me it happening without the cage.
Re: Carrier bearings - how to remove? [Re: HealthServices] #593983
01/26/10 01:52 PM
01/26/10 01:52 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i think if you were to be grabbing the cage with that puller, you'd detroy the bearing by twisting the cage in to a pretzel.
you need to get the fingers of the puller onto the inner race or else
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
