Iron Disc Shelling #592547
01/24/10 11:34 AM
01/24/10 11:34 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Ever see this before?
Sinstered iron disc,no clue the was a problem was working fine.
No heat marks.
Just looks like the facing never bonded?
Any experience?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Iron Disc Shelling [Re: 6bblFLASH] #592548
01/24/10 12:22 PM
01/24/10 12:22 PM
MN
JERICOGTX Online content
JERICOGTX  Online Content
MN
Yup, seen it before, and if you ask McLeod, they will say it's "normal". Has happened to a buddy of mine. McLeod told him to reinstall it until it wasn't working any more. He raced it quite a while after that... Never have had it happen with mine, and I've been through 3 disc's now. IF you do want to fix it, send the clutch to Tim Hyatt. After he reworked my clutch, it has been the best it has ever been. Mine will go back to him before going back to McLeod.
Jeff
69 GTX 68 Road Runner
Re: Iron Disc Shelling [Re: JERICOGTX] #592549
01/24/10 02:22 PM
01/24/10 02:22 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho doesn't seem like a very bright idea to run something like that given the imbalance it would create
Re: Iron Disc Shelling [Re: jamesc] #592550
01/24/10 02:41 PM
01/24/10 02:41 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Besides balance, it would be a good way to ruin some other things to.
Re: Iron Disc Shelling [Re: rowin4] #592551
01/24/10 03:36 PM
01/24/10 03:36 PM
N.E. Ohio
N.E. Ohio
NO WAY it will be run again till repaired.
I`m getting the "failure is normal" vibe from the soft-lok bunch.
Re: Iron Disc Shelling [Re: 6bblFLASH] #592552
01/24/10 04:12 PM
01/24/10 04:12 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
it's the consumable part - kinda scary looking though - and to have that thing buzzin around 7000 grand put another couple of 100's in your hand and have a good laugh
Re: Iron Disc Shelling [Re: 6bblFLASH] #592553
01/24/10 08:19 PM
01/24/10 08:19 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
No consistancy in slippage with varying surface area, cant believe McCleod would say run it.
Re: Iron Disc Shelling [Re: 6bblFLASH] #592554
01/25/10 12:42 AM
01/25/10 12:42 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
What brand is that?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Iron Disc Shelling [Re: DemonDust] #592555
01/25/10 08:19 AM
01/25/10 08:19 AM
N.E. Ohio
N.E. Ohio
What brand is that?
McLeod
Re: Iron Disc Shelling [Re: 6bblFLASH] #592556
01/25/10 10:31 AM
01/25/10 10:31 AM
MN
MN
Do NOT send it back to McLeod... Send it to Tim Hyatt. It will be fixed right, and come with a thicker disc. Plus it will be cheaper then sending it back to mcLeod.
Jeff
Re: Iron Disc Shelling [Re: JERICOGTX] #592557
01/25/10 09:53 PM
01/25/10 09:53 PM
N.E. Ohio
N.E. Ohio
Jeff
I talked with McLeod today,said they would replace it "free of charge". So thats what I will do for now.
Re: Iron Disc Shelling [Re: 6bblFLASH] #592558
01/25/10 10:06 PM
01/25/10 10:06 PM
MN
MN
Can't beat that deal. Are they going to resurface the pressure plate, and flywheel also?
Jeff
Re: Iron Disc Shelling [Re: 6bblFLASH] #592559
01/25/10 10:53 PM
01/25/10 10:53 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
free is good, well sort of free
i suspect that all of the readily available sintered iron disks are made at the same place, have a ram disk that looks just like my mcleod disk.....funny
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Iron Disc Shelling [Re: oldiron] #592560
01/25/10 11:38 PM
01/25/10 11:38 PM
N.E. Ohio
N.E. Ohio
I`m sending the whole thing back and see what they say.
I want to start fresh regardless who does the work or pays.
Re: Iron Disc Shelling [Re: oldiron] #592561
01/26/10 09:10 AM
01/26/10 09:10 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
My Ram disc has V grooves in it.
SDG Motorsports
