Iron Disc Shelling
#592547
01/24/10 11:34 AM
01/24/10 11:34 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Ever see this before? Sinstered iron disc,no clue the was a problem was working fine. No heat marks. Just looks like the facing never bonded? Any experience?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Iron Disc Shelling
[Re: 6bblFLASH]
#592548
01/24/10 12:22 PM
01/24/10 12:22 PM
Posts: 10,027 MN
JERICOGTX
MN
Yup, seen it before, and if you ask McLeod, they will say it's "normal". Has happened to a buddy of mine. McLeod told him to reinstall it until it wasn't working any more. He raced it quite a while after that... Never have had it happen with mine, and I've been through 3 disc's now. IF you do want to fix it, send the clutch to Tim Hyatt. After he reworked my clutch, it has been the best it has ever been. Mine will go back to him before going back to McLeod.
Jeff
69 GTX
68 Road Runner
[Re: rowin4]
#592551
01/24/10 03:36 PM
01/24/10 03:36 PM
6bblFLASH
N.E. Ohio
NO WAY it will be run again till repaired. I`m getting the "failure is normal" vibe from the soft-lok bunch.
[Re: 6bblFLASH]
#592553
01/24/10 08:19 PM
01/24/10 08:19 PM
Posts: 2,172 Ohio
theclutcher
Ohio
No consistancy in slippage with varying surface area, cant believe McCleod would say run it.
[Re: 6bblFLASH]
#592556
01/25/10 10:31 AM
01/25/10 10:31 AM
Posts: 10,027 MN
JERICOGTX
MN
Do NOT send it back to McLeod... Send it to Tim Hyatt. It will be fixed right, and come with a thicker disc. Plus it will be cheaper then sending it back to mcLeod.
Jeff
69 GTX
68 Road Runner
[Re: 6bblFLASH]
#592559
01/25/10 10:53 PM
01/25/10 10:53 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
free is good, well sort of free i suspect that all of the readily available sintered iron disks are made at the same place, have a ram disk that looks just like my mcleod disk.....funny
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#592560
01/25/10 11:38 PM
01/25/10 11:38 PM
6bblFLASH
N.E. Ohio
I`m sending the whole thing back and see what they say. I want to start fresh regardless who does the work or pays.
[Re: oldiron]
#592561
01/26/10 09:10 AM
01/26/10 09:10 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
My Ram disc has V grooves in it.
