Carb selection for 383 #591617
01/23/10 05:36 PM
01/23/10 05:36 PM
Ensenada Mexico
Slims63FURY Offline OP
Ensenada Mexico
Currently building a 383 for a 63 Fury and I'll most likely drop a 4 bbl in it. Just wondering what the general feel was about going with a new electronic Carb vs. an original Carter AVS. Holly (Model 4160) and Edelbrock (model 1406) make some nice looking carbs. Just thinking price wise it would be the same or even a bit cheaper to just buy a new Carb vs. buying an old one and having it torn apart and rebuilt.
Thanks Ya'll
Check out the story of this Family Classic http://63plymouth.com/Donna's Fury.html
Re: Carb selection for 383 [Re: Slims63FURY] #591618
01/23/10 05:53 PM
01/23/10 05:53 PM
what's your intent w the car, daily driver or some hot rodding? A 600 eddy would work good. All oe AVS's are emission carbs and have 40 yr old tech and 40 yrs of wear. Would need eddy 2 step rods/pri jets/flat rod covers to change the main metering but for a daily driver they'd be fine.
Re: Carb selection for 383 [Re: RapidRobert] #591619
01/23/10 05:57 PM
01/23/10 05:57 PM
Ensenada Mexico
Ensenada Mexico
It's just going to be a daily driver, no intentions of hitting the 1/4 mile,,,just smoke the tires now and then. Those Eddy's do look nice!
Re: Carb selection for 383 [Re: Slims63FURY] #591620
01/23/10 06:01 PM
01/23/10 06:01 PM
[quote Those Eddy's do look nice!
Yes they do. I have one, the elec choke version on my 318, I think it's a 1406.
Re: Carb selection for 383 [Re: Slims63FURY] #591621
01/23/10 06:02 PM
01/23/10 06:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you're going to keep the motor bone stock, I'd be going with something like a holley 650cfm 4150 carb. If you want to do a little hot rodding like a set of headers and a mild cam, then I'd go with the traditional performance carb, the holley 750cfm 3110.
Re: Carb selection for 383 [Re: DaytonaTurbo] #591622
01/23/10 07:46 PM
01/23/10 07:46 PM
California
darkrider2 Offline
darkrider2  Offline
California
Re: Carb selection for 383 [Re: DaytonaTurbo] #591623
01/24/10 12:07 AM
01/24/10 12:07 AM
Ensenada Mexico
Ensenada Mexico
Won't be able to do any headers now, but it's on my list to someday do that. Putting in Speed-Pro Pistons and a comp cam Xtreme Energy at a duration of 218 in - 224 ex. So I think it's some what of a mild build, but it should be a fun ride. I'll for sure take note on there Carb suggestions,,,thanks everyone.
