single plane intake for 416 #591413
01/23/10 09:39 AM
01/23/10 09:39 AM
PA
maxwedge1 Offline OP
PA
considering a victor or m1.
currently running wieand stealth.
mildly ported x-heads,hughes cam .540ish lift.
motor seems to flatten out around 5000rpm or so,wondering if the intake is restricting upper rpm power?
Re: single plane intake for 416 [Re: maxwedge1] #591414
01/23/10 09:57 AM
01/23/10 09:57 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I have a 406" and had an airgap on it. I switched to an M1 and I love it. It actually picked up the 60' and gave me another 600 rpm of power. I only have the MP crate motor cam with .501/.513 lift (hyd roller) so I was shocked the intake made this much differance. It was also good for .45 on the ET. Give it a try.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: single plane intake for 416 [Re: maxwedge1] #591415
01/23/10 12:25 PM
01/23/10 12:25 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
You are running X heads on the stroker ?? it must be begging for air !!!!
How much are you running in the 1/4 ?
Dan
Re: single plane intake for 416 [Re: Wedgeman] #591416
01/23/10 04:27 PM
01/23/10 04:27 PM
PA
PA
havent been to a track with this motor. but on the street it seems to hold its own with 12 sec cars.
I realise the iron heads keep it from true potential but the x's won out over $$eddies.
i beleive i did a decent job porting the x's were they shouldnt be done at 5000 rpm, just lookin for another 1000 rpm without major surgery.
Re: single plane intake for 416 [Re: maxwedge1] #591417
01/23/10 06:53 PM
01/23/10 06:53 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm running a Victor 340 on my 408. 1" - 4 hole Wilson spacer and a Mighty Demon 750 annular. Combo works good for me.
Fastest 300
Re: single plane intake for 416 [Re: maxwedge1] #591418
01/23/10 07:00 PM
01/23/10 07:00 PM
W
Wedgeman Offline
Wedgeman  Offline
W
IT's not the Iron ! it's the breathing.....My build plan for Iron heads (RHS)....
Dan
Re: single plane intake for 416 [Re: maxwedge1] #591419
01/24/10 01:07 AM
01/24/10 01:07 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
I'm running the M1 with R/T Big Valve Heads..... Pull's hard to 6500.....
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: single plane intake for 416 [Re: maxwedge1] #591420
01/24/10 10:34 AM
01/24/10 10:34 AM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
another good intake would be the Holley Strip
Dominator.
Re: single plane intake for 416 [Re: maxwedge1] #591421
01/24/10 02:29 PM
01/24/10 02:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What's the duration on you're cam? I run a Victor on my 408, but I probably have more duration.
Re: single plane intake for 416 [Re: maxwedge1] #591422
01/24/10 08:12 PM
01/24/10 08:12 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I run a Super Victor on my 408 and my stats are in my sig.
408 590 MP cam,eddy heads,750hp.TTI headers
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
