Page 3 of 3 1 2 3
Re: My '68 Charger restoration [Re: ] #587475
03/27/10 12:12 PM
03/27/10 12:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks like you are taking on a big project. Good luck.
Re: My '68 Charger restoration [Re: 67Charger] #587476
03/29/10 02:33 AM
03/29/10 02:33 AM
CA, USA
JcodeCharger Offline
CA, USA
I've got a full boogie blasting setup at work, with the proper Bullard forced air hood, air supply, 175 CFM compressor and about 75 tons of #90 silica. Probably can get it blasted next week.
I don't know of anywhere down here that can dip a full car.
First off your wife should win an award for being so supportive of your hobby. Secondly, I think its great when another car gets saved from the wrecker. I have a feeling it will turn out very nice.
There are 2 places near you who can do chemical stripping in your area. One is Paint Stripping Corp. in Santa Fe Springs and the other is Strip Clean in Santa Ana. I have used both with excellent results. Obviously dipping a car isnt cheap and it sounds like you have all you need to blast your car already. I just thought that I would let you know about these two places. For a car this rusty its just extra insurance to have it dipped over blasted. Good luck and congrats on your midlife crisis car!
68 twin turbo Dart 8.19 so far
70 Swinger 360
69 Roadrunner 383 4 speed
69 Mod Top Satellite 383 auto
69.5 A12 Super Bee 4 speed
70 T/A Challenger
70 FC7 Duster 340 4 speed
70 FJ5 Superbird
68 Hemi 4 speed Roadrunner
71 Duster W2 340
Re: My '68 Charger restoration [Re: JcodeCharger] #587477
05/24/10 06:45 PM
05/24/10 06:45 PM
Erda, UT
67Charger Offline OP
Erda, UT
Well, it's been really busy lately, and I've been rather distracted with work and converting the '67 to a Open Road Race car, but that's getting back under control. I've got another '67 Charger that I bought as a parts car years ago, but never could cut it up since I decided it would make a good start for a gutted 150+ mph road racer for the Silver State Classic. Well, we've gotten our hands on a stock car, so the plans for the parts '67 are gone, and it may now go back to being a parts car, but for the '68. The cowl, door pillars and lots of other parts are interchangable and needed. Another week or two and I should get it blasted.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: My '68 Charger restoration [Re: 67Charger] #587478
05/25/10 11:04 PM
05/25/10 11:04 PM
What!......... no update pics with your post?
Re: My '68 Charger restoration [Re: 67Charger] #587479
06/09/10 05:59 PM
06/09/10 05:59 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
that's alot of work, but hang in there. glad to see another Charger saved. great wife!
1981 Dodge D150 360 auto
Re: My '68 Charger restoration [Re: 67Charger] #587480
06/26/10 05:04 AM
06/26/10 05:04 AM
Erda, UT
Erda, UT
Tonight's progress - One pitted cowl removed and a metric butt-load of crap exposed. NASTY! What I find most disturbing is the fact that I had already vacuumed it out "good enough" before even considering removing it for replacement. I cannot even imagine what a disaster that would have caused later on.
Re: My '68 Charger restoration [Re: 67Charger] #587481
06/26/10 10:52 AM
06/26/10 10:52 AM
You certianly are a brave soul. Do people say you are stuborn?
Re: My '68 Charger restoration [Re: ] #587482
06/26/10 11:03 AM
06/26/10 11:03 AM
Erda, UT
Erda, UT
Yes! How did you know?
...I prefer "determined," "dedicated," or "task oriented."
Re: My '68 Charger restoration [Re: 67Charger] #587483
07/17/10 09:53 PM
07/17/10 09:53 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I saw those new AMD reproduction cowls at Carlisle. Man are they nice.
Re: My '68 Charger restoration [Re: 69Cuda340S] #587484
01/23/11 04:04 AM
01/23/11 04:04 AM
Erda, UT
Erda, UT
Here's a little update...
I blasted until the sun went down them shot all the bare metal with PPG DP50LF Epoxy Primer.
I've had 2 good fenders and some patch parts media blasted and they are waiting in the wings. More sandblasting to the chassis is on the menu, but work has been really busy.
Re: My '68 Charger restoration [Re: 67Charger] #587485
01/23/11 01:51 PM
01/23/11 01:51 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Hey, nice work
And lots of it!
How are those castors attached?
Re: My '68 Charger restoration [Re: RemCharger] #587486
01/23/11 04:53 PM
01/23/11 04:53 PM
Erda, UT
Erda, UT
Hey, nice work
And lots of it!
Thanks!
The casters use a piece of cut-open rectangular tubing that has the same inside dimension as the width of the frame rail. I lined them up with an existing hole so I could pass a bolt through as a retainer, but they were such a perfect fit I actually had to tap them on with a rubber mallet. They don't fall off. In hind sight, I should have made the channel about a foot long, then it wouldn't want to tuck under undaer any circumstance. Once I get to rolling it around I'll put a bolt in for safety. The rears (not shown) use and old set of front spring hangers with a flat plate across the bottom instead of the 3 sided channel, and then the same 3 1/2" vertical spacer.
Re: My '68 Charger restoration [Re: 67Charger] #587487
05/07/11 10:51 PM
05/07/11 10:51 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
lo's of work but looking good
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: My '68 Charger restoration [Re: aspenrt360] #587488
05/08/11 08:41 PM
05/08/11 08:41 PM
Erda, UT
Erda, UT
As promised, an update. I'm trying not to remove entire substructure panels, but rather splice in good for bad to hopefully preserve factory fitment since there will always be other pieces holding the alignment in check. The trunk floor will remain and the bad center section clearanced out for a custom rectangular cell mounted midway through the floor for added clearance, but will still fill with the factory filler.
Drivers Side behind the 1/4. No unpleasant surprises
Trunk extension survived, will need minor pin-hole repair.
Exposing the trunk rails to salvage them and the stamped VIN
Passenger side was a little worse. I have a new section of rocker to replace most of the missing area without removing the ENTIRE rocker.
Door hinge post. Going to splice in new (donor car) piece.
Front P/S frame rail. Needs more cut away. Have donor rail, just determining the size of the splice.
Page 3 of 3 1 2 3
