Edelbrock Gasgacinch #586881
01/18/10 07:42 PM
01/18/10 07:42 PM
Sandy, OR
DART67GT Offline OP
DART67GT  Offline OP
Sandy, OR
I'm ready to install my Air Gap intake to the Eddy heads. The instructions say to use the Gascacinch sealant on the gaskets. I have some, but the instructions on the can differ from the intake install instructions. Has anyone used this stuff? Do I just use on the head and the head side of the gasket? Is anything required on the intake side? I'm using Felpro gasket 1213.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: Edelbrock Gasgacinch [Re: DART67GT] #586882
01/18/10 08:06 PM
01/18/10 08:06 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I'd use it on both sides of the gasket. Probably a lot like the "Indian Head" shellac/sealer.
Re: Edelbrock Gasgacinch [Re: DART67GT] #586883
01/18/10 08:16 PM
01/18/10 08:16 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I don't think you want it on the synthetic rubber bead.
Many Fel-Pro Performance Intake manifold gaskets utilize a synthetic rubber bead where applicable for superior sealing around intake and coolant ports.
http://www.jegs.com/i/Fel-Pro/375/1213/10002/-1#
Re: Edelbrock Gasgacinch [Re: Lefty] #586884
01/18/10 08:57 PM
01/18/10 08:57 PM
sparingly on both sides and I'd toss the end (front/rear) supplied gaskets and use a wide/thick swath of clear silicone instead on CLEANED block/intake surfaces.
