Spark Plug Choice HEMI pump gas alum heads RC9YC #585341
01/17/10 01:33 PM
01/17/10 01:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Is the Champion RC9YC a good choice for the following engine?
528 HEMI
10,5:1 CR
ALUM HEADS
SOLID ROLLER CAM 250º @ 0,050" UNDER ,600 LIFT
PUMP GAS
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585342
01/17/10 02:10 PM
01/17/10 02:10 PM
I have used both the RC12YC and RC9YC on my edddy RPM aluminum headed 518 wedge with 10.29 to 1 comp and my 464 Eddy headed 10.46 to 1 comp. ratio little motor Both work well on the street and at the track with those plugs, BTW I am at 3000 FT above sea level also
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: Cab_Burge] #585343
01/17/10 02:11 PM
01/17/10 02:11 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
I only run autolites, AR52
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: prochargedhemi] #585344
01/17/10 08:33 PM
01/17/10 08:33 PM
The AR52 are pretty cold for a street car on pump gas If I was going to use the 13/16 size spark plug bodys I would probally use the Autolite 53 or 54, or the resistor plugs in the same heat range( I can't remember those numbers right now )
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: Cab_Burge] #585345
01/19/10 04:56 PM
01/19/10 04:56 PM
pa
572charger Offline
572charger  Offline
pa
autolites 65 on the street and 63 at the track !
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: Cab_Burge] #585346
01/19/10 05:01 PM
01/19/10 05:01 PM
Temperance, MI
P
P
Temperance, MI
I just cross referenced the accells that barton had put in it and that was the autolite number. I run c12 at all times so not really sure
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585347
01/19/10 05:14 PM
01/19/10 05:14 PM
AndyF Offline
AndyF  Offline
The RC9YC plug should work fine for your application.
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: AndyF] #585348
01/20/10 10:07 PM
01/20/10 10:07 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
thx for the info....
71 GTX 4sp Dana GY9 HD Road King
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: prochargedhemi] #585349
01/21/10 03:19 AM
01/21/10 03:19 AM
MD
HEMI472 Online content
HEMI472  Online Content
MD
what was the accells number??????????
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: AndyF] #585350
01/21/10 09:59 AM
01/21/10 09:59 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the info guys!
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585351
11/15/12 01:09 PM
11/15/12 01:09 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
what about champion C-63YC
would it be a better choice?
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585352
11/15/12 04:12 PM
11/15/12 04:12 PM
Definetly NOT There way to cold for a low compression pump gas motor unless you run it really lean at idle and part throttle, I wouldn't. Champion uses a numbering system that the smaller the numbers the colder the plug is The C63YC is a 5/8 body plug with a protruded gap and a copper center electrode that is a little hotter than a RN6YC or N6YC would be
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: Cab_Burge] #585353
11/15/12 04:25 PM
11/15/12 04:25 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
These are the plugs I have:
champion RC9YC: I think heat range is 5??? for 10,5:1 with alum heads
Champion RN12YC: Heat range 4??? for under 9:1 with alum heads???
Champion C61YC: heat Range 9??? for 12:1 with alum heads
NGK 7173: heat range 8??? for 11:1 with alum heads???
Are my above statemets true?
Should I try the RC9YC first and go from there?
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585354
11/15/12 06:43 PM
11/15/12 06:43 PM
I would try the RC9YC first and then the RN12YC after getting the tune up the way you want it and determine which plugs you like the best
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: Cab_Burge] #585355
11/15/12 07:32 PM
11/15/12 07:32 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
will do!!! thanks!!!
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585356
11/15/12 09:46 PM
11/15/12 09:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Any suggestions on where to gap the plugs at? Im gonna be running an MSD 7AL
Re: Spark Plug Choice HEMI pump gas alum heads RC9YC [Re: domingo] #585357
11/15/12 11:14 PM
11/15/12 11:14 PM
I like and use between .045 and .060
