Re: Spark Plug Choice HEMI pump gas alum heads RC9YC
[Re: prochargedhemi]
#585344
01/17/10 08:33 PM
01/17/10 08:33 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
The AR52 are pretty cold for a street car on pump gas If I was going to use the 13/16 size spark plug bodys I would probally use the Autolite 53 or 54, or the resistor plugs in the same heat range( I can't remember those numbers right now )
[Re: Cab_Burge]
#585345
01/19/10 04:56 PM
01/19/10 04:56 PM
Posts: 1,629 pa
572charger
pa
autolites 65 on the street and 63 at the track !
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Cab_Burge]
#585346
01/19/10 05:01 PM
01/19/10 05:01 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
I just cross referenced the accells that barton had put in it and that was the autolite number. I run c12 at all times so not really sure
