Advice/adhesive help needed for a broken Cuda grill #583232
01/15/10 11:32 AM
01/15/10 11:32 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I have a broken 70 Barracuda grill that I am trying to resurrect. What adhesives work well? I need some techniques/tips to to help me out as well. Let me know what you've done/what's worked. Thanks
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Advice/adhesive help needed for a broken Cuda grill [Re: 70B5Cuda] #583233
01/15/10 12:00 PM
01/15/10 12:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
3M's 8115 structural adhesive - it's a 2-part glue.
Re: Advice/adhesive help needed for a broken Cuda grill [Re: topside] #583234
01/15/10 12:03 PM
01/15/10 12:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess it would depend on the crack, and how big. I used a 2 part like the above to fix my 70 grill. Once painted you'd never know it was there.
Coming soon!!!!
Re: Advice/adhesive help needed for a broken Cuda grill [Re: Mr.Yuck] #583235
01/15/10 12:13 PM
01/15/10 12:13 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The grill is pretty bad. It has some cracks but also has some broken pieces.
Re: Advice/adhesive help needed for a broken Cuda grill [Re: 70B5Cuda] #583236
01/15/10 01:14 PM
01/15/10 01:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If the Grill is really bad, they aren't worth saving anymore, call Mike Ross at BEA Parts and get a 70 Grille before their gone, cause once they're gone, they're gone for good, so don't be left holding the bag on this one, sell your old grill, there's allways someone willing to invest the effort in saving 40 yr old plus brittle plastic
Re: Advice/adhesive help needed for a broken Cuda grill [Re: DAYCLONA] #583237
01/17/10 10:46 AM
01/17/10 10:46 AM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I agree with Dayclona on the old plastic, it is brittle and probably not worth the effort. But.......sometimes it's worth it, take my '68 Camaro SS grille........it was fairly new, but was broken and on Ebay for $15. It was broken from the lower corner to just under the running light. Easy fix, I ground troughs and valleys on the backside, and put clear tape on the front, to keep the glue from seeping too far. The glue penetrates all the way, yet doesn't turn into a hard to sand mess on the side you see. Then, I 80 grit with a DA, use regular bondo to smooth, and prime with etching primer. I have several repaired this way, and they haven't cracked in many years.
Re: Advice/adhesive help needed for a broken Cuda grill [Re: 4BBodies] #583238
01/17/10 10:55 AM
01/17/10 10:55 AM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
The Seller's before pic....I just got it from Ebay. Not great, but you can see it was a long crack.
