Advice/adhesive help needed for a broken Cuda grill
#583232
01/15/10 11:32 AM
01/15/10 11:32 AM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
I have a broken 70 Barracuda grill that I am trying to resurrect. What adhesives work well? I need some techniques/tips to to help me out as well. Let me know what you've done/what's worked. Thanks
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: Advice/adhesive help needed for a broken Cuda grill
[Re: Mr.Yuck]
#583235
01/15/10 12:13 PM
01/15/10 12:13 PM
70B5Cuda
Newton, KS
The grill is pretty bad. It has some cracks but also has some broken pieces.
[Re: DAYCLONA]
#583237
01/17/10 10:46 AM
01/17/10 10:46 AM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
I agree with Dayclona on the old plastic, it is brittle and probably not worth the effort. But.......sometimes it's worth it, take my '68 Camaro SS grille........it was fairly new, but was broken and on Ebay for $15. It was broken from the lower corner to just under the running light. Easy fix, I ground troughs and valleys on the backside, and put clear tape on the front, to keep the glue from seeping too far. The glue penetrates all the way, yet doesn't turn into a hard to sand mess on the side you see. Then, I 80 grit with a DA, use regular bondo to smooth, and prime with etching primer. I have several repaired this way, and they haven't cracked in many years.
