2001 Caravan Tranny question #582294
01/14/10 03:02 PM
01/14/10 03:02 PM
Missouri
Confusedcuda Offline OP
Missouri
Hello all, I have a 2001 Dodge Caravan with 174,000 miles. Yesterday I was driving my kids to the sitter and noticed it would not shift on the hiway from 3rd to 4th. at 50 mph I was hitting about 3800 rpm. I got to my sitters, the van was off for about 20 minutes, hopped in it and it drove fine. Shifted like it always has. Today I hopped in it went about 3 miles, once again it would not shift up on the hiway. I pulled over waited a couple of minutes, shutting van off, then restarted and it drove fine. I wonder if I should try changing the tranny fluid and filter, I checked it and it looked fine(not burned or n othing, maybe dirty) also we have had about 2 feet os snow here and I drove through some deep snow all weekend, is there something that could of came loose or something? Thanks
Re: 2001 Caravan Tranny question [Re: Confusedcuda] #582295
01/14/10 04:51 PM
01/14/10 04:51 PM
Missouri
Missouri
Bump
Re: 2001 Caravan Tranny question [Re: Confusedcuda] #582296
01/14/10 07:47 PM
01/14/10 07:47 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
it sounds like its going in what is called limp mode when the computer see a problem it gets stuck in 2nd gear when you shut it off the computer reboots and it will shift until the computer see the problem again it needs to be scaned so you can find the problem.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 2001 Caravan Tranny question [Re: dusturbd340W5] #582297
01/14/10 08:26 PM
01/14/10 08:26 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
My wifes van did the same thing once and turning it off for a few seconds "cured" it and it hasn't done it yet. I beleive this is also what my aunts mini van did and she had it diagnosed and they said it was the shift solinoid.
She had them replace it and to my knowledge it hasn't done it since.
Re: 2001 Caravan Tranny question [Re: WILD BILL] #582298
01/14/10 09:59 PM
01/14/10 09:59 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
Check engine light is on??Most likely has some stored trans codes.Have it checked.sounds like the o.d. is going out.bad converter or a solenoid pack.Speedo working?/ speed sensors are also common to fail.But,The last one I looked at with that similiar problem,completely let go a week later.stopped moving.fluid was good and clean on that one.Don't guess,have it checked out.At least scan the computer if the lights on.There is no check trans light.It all goes through the engine light.The engine controler will have a p0700 code witch means trans fault.need a scanner capable of doing transmissions.
Re: 2001 Caravan Tranny question [Re: moretoys] #582299
01/14/10 10:04 PM
01/14/10 10:04 PM
Missouri
Missouri
No check engine lights no nothing. Just took off one day in it and it all the sudden would'nt shift into 4th. I had to do 45mph to where I was going. After it sat for 10 mins. It ran fine. It has done it one other time and I pulled over and shut the van off and started it back up and it ran fine. It has been very cold here also. It is almost like it needs to warm up real good. I think I am going to start with a filter and fluid change. I have also read of solenoid packs going out to.
Re: 2001 Caravan Tranny question [Re: Confusedcuda] #582300
01/14/10 11:22 PM
01/14/10 11:22 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Our 99 doesn't shift into OD till it warms up a little, and I don't think it's supposed to either. I'd be inclined to think a filter/fluid change wouldn't hurt. Sometimes just connections with the wiring and sensors will cause this too.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 2001 Caravan Tranny question [Re: Magnumguy] #582301
01/15/10 08:52 PM
01/15/10 08:52 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if u like doing your own work and not afraid to spend a few bucks....it sounds to me like the solenoid pack...cost about a hundred bucks....change that with the filter and atf-4 oil...otherwise a dealer will have to check it for u....mine was the pack....dorman makes the aftermarket one...good luck...it's cold out there..
Re: 2001 Caravan Tranny question [Re: AARCONV] #582302
01/15/10 11:50 PM
01/15/10 11:50 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
I'd pull the pan and make sure you're not working on other problems first. Then if it looks good inside, clean the connections on the solonoid pack and remove the input and output speed sensors and clean them too. You could do the speed sensor and connection cleaning first and see where you get. Solonoid packs are about 240 up here and speed sensors are 40 each.
Don.
