2001 Caravan Tranny question
#582294
01/14/10 03:02 PM
01/14/10 03:02 PM
Posts: 337 Missouri
Confusedcuda
Missouri
Hello all, I have a 2001 Dodge Caravan with 174,000 miles. Yesterday I was driving my kids to the sitter and noticed it would not shift on the hiway from 3rd to 4th. at 50 mph I was hitting about 3800 rpm. I got to my sitters, the van was off for about 20 minutes, hopped in it and it drove fine. Shifted like it always has. Today I hopped in it went about 3 miles, once again it would not shift up on the hiway. I pulled over waited a couple of minutes, shutting van off, then restarted and it drove fine. I wonder if I should try changing the tranny fluid and filter, I checked it and it looked fine(not burned or n othing, maybe dirty) also we have had about 2 feet os snow here and I drove through some deep snow all weekend, is there something that could of came loose or something? Thanks
Re: 2001 Caravan Tranny question
[Re: Confusedcuda]
#582296
01/14/10 07:47 PM
01/14/10 07:47 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
it sounds like its going in what is called limp mode when the computer see a problem it gets stuck in 2nd gear when you shut it off the computer reboots and it will shift until the computer see the problem again it needs to be scaned so you can find the problem.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
