solid roller tell me
#581437
01/13/10 07:14 PM
01/13/10 07:14 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
what you think about this cam it will be going in my 416 with cnc'd Indybrocks
.684 intake .675 exhaust 274/280 @ 50 with a 106 lobe sep. 305/316 adver. der .022/.024 lash
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: solid roller tell me
[Re: dusturbd340W5]
#581438
01/13/10 07:35 PM
01/13/10 07:35 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Putting it in (straight up) would look like this..
IVO 31 BTDC IVC 63 ABDC EVO 66 BBDC EVC 34 ATDC
Whats the numbers at .200 look like? Whats this going in and whats the weight? Give some more info, so some of the smarter guys on the board can comment....my self..I dont know if the tight lobe centers is idea, whats the purpose of the engine, street or track?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#581439
01/13/10 07:53 PM
01/13/10 07:53 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
That leaves me out
[Re: AndyF]
#581441
01/13/10 08:04 PM
01/13/10 08:04 PM
dusturbd340W5
Kissimmee Fl.
drag only motor car weights 2961 w/driver t-brake 4.88 gear 32x14x15 M/T thats the only specs I have I launch at 48-5000 shift at 6500 the cam that is in the motor is way small need something bigger.The cam thats in the motor is ok in the 1/8 but stops pulling about 1000' in the 1/4 and I know I am leaving a lot on the table.
[Re: dusturbd340W5]
#581443
01/13/10 08:13 PM
01/13/10 08:13 PM
dusturbd340W5
Kissimmee Fl.
just saw that Ryan recomened .276/289 @ 50 with a .710-.720 lift with a 108 for a smaller motor with W-5s I know those are better heads but still less CI
[Re: AndyF]
#581444
01/13/10 08:25 PM
01/13/10 08:25 PM
Quicktree
I have no idea what you're trying to do with that engine but it is a big honking cam for a 416. The cam I had in my 505 motor that made 800+ hp was only 266/272 in duration at 0.050. So you're bigger than that with a much smaller motor.
you really think thats a large cam
[Re: S/ST 3040]
#581448
01/13/10 10:02 PM
01/13/10 10:02 PM
dusturbd340W5
Kissimmee Fl.
Thanks Vic any other opinions all welcome.
[Re: dizuster]
#581450
01/13/10 11:52 PM
01/13/10 11:52 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Just be careful over camming the small port. In the end you may loose more down low, then you gain up top...
Yes.
The 1st cam you mentioned would definitely be on big side for your compression/heads/converter. I just replied to your PM from other day. Sorry been swamped W/ work & taking while to get PM's emails/calls done lately.
That Crower you PM'd me about would not be bad, it's still hair small but, step in right direction.
[Re: RyanJ]
#581451
01/14/10 12:20 AM
01/14/10 12:20 AM
Yes.
it sounds like the same type of reply i gave. about 10 degree's more than the one you pm'd me about will do the job very well based on the info i have of your combo.
