solid roller tell me #581437
01/13/10 07:14 PM
01/13/10 07:14 PM
Kissimmee Fl.
dusturbd340W5 Offline OP
Kissimmee Fl.
what you think about this cam it will be going in my 416 with cnc'd Indybrocks
.684 intake
.675 exhaust
274/280 @ 50
with a 106 lobe sep.
305/316 adver. der
.022/.024 lash
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: solid roller tell me [Re: dusturbd340W5] #581438
01/13/10 07:35 PM
01/13/10 07:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Putting it in (straight up) would look like this..
IVO 31 BTDC
IVC 63 ABDC
EVO 66 BBDC
EVC 34 ATDC
Whats the numbers at .200 look like?
Whats this going in and whats the weight?
Give some more info, so some of the smarter guys on the board can comment....my self..I dont know if the tight lobe centers is idea, whats the purpose of the engine, street or track?
Re: solid roller tell me [Re: Bob_Coomer] #581439
01/13/10 07:53 PM
01/13/10 07:53 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
IVO 31 BTDC
IVC 63 ABDC
EVO 66 BBDC
EVC 34 ATDC
That leaves me out
Re: solid roller tell me [Re: dusturbd340W5] #581440
01/13/10 07:58 PM
01/13/10 07:58 PM
AndyF Offline
AndyF  Offline
I have no idea what you're trying to do with that engine but it is a big honking cam for a 416. The cam I had in my 505 motor that made 800+ hp was only 266/272 in duration at 0.050. So you're bigger than that with a much smaller motor.
Re: solid roller tell me [Re: AndyF] #581441
01/13/10 08:04 PM
01/13/10 08:04 PM
Kissimmee Fl.
Kissimmee Fl.
drag only motor car weights 2961 w/driver t-brake 4.88 gear 32x14x15 M/T thats the only specs I have I launch at 48-5000 shift at 6500 the cam that is in the motor is way small need something bigger.The cam thats in the motor is ok in the 1/8 but stops pulling about 1000' in the 1/4 and I know I am leaving a lot on the table.
Re: solid roller tell me [Re: dusturbd340W5] #581442
01/13/10 08:13 PM
01/13/10 08:13 PM
AndyF Offline
AndyF  Offline
If you're shifting a 416 motor at 6500 rpm then I don't think you need a cam that is more than 270 at 050. Just seems way too big to me. Those heads should be good enough that you don't need to crutch it with a huge cam.
Re: solid roller tell me [Re: dusturbd340W5] #581443
01/13/10 08:13 PM
01/13/10 08:13 PM
Kissimmee Fl.
Kissimmee Fl.
just saw that Ryan recomened .276/289 @ 50 with a .710-.720 lift with a 108 for a smaller motor with W-5s I know those are better heads but still less CI
Re: solid roller tell me [Re: AndyF] #581444
01/13/10 08:25 PM
01/13/10 08:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you really think thats a large cam
Re: solid roller tell me [Re: dusturbd340W5] #581445
01/13/10 08:32 PM
01/13/10 08:32 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
.684 intake
.675 exhaust
274/280 @ 50
305/316 adver. der
.022/.024 lash
What's your compression ratio Woody?
Re: solid roller tell me [Re: S/ST 3040] #581446
01/13/10 08:35 PM
01/13/10 08:35 PM
Kissimmee Fl.
Kissimmee Fl.
12.6-1
Re: solid roller tell me [Re: dusturbd340W5] #581447
01/13/10 08:43 PM
01/13/10 08:43 PM
S/ST 3040 Offline
S/ST 3040  Offline
264º/270º @ .050" .700"+ IN .660" EX
108º LSA +4º
Re: solid roller tell me [Re: S/ST 3040] #581448
01/13/10 10:02 PM
01/13/10 10:02 PM
Kissimmee Fl.
Kissimmee Fl.
Thanks Vic
any other opinions all welcome.
Re: solid roller tell me [Re: dusturbd340W5] #581449
01/13/10 11:21 PM
01/13/10 11:21 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Are you sure it's the cam that's killing the top end? An indybrock on a 416" motor isn't really gonna be an RPM screaming combo....
Just be careful over camming the small port. In the end you may loose more down low, then you gain up top...
Re: solid roller tell me [Re: dizuster] #581450
01/13/10 11:52 PM
01/13/10 11:52 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Yes.
The 1st cam you mentioned would definitely be on big side for your compression/heads/converter. I just replied to your PM from other day. Sorry been swamped W/ work & taking while to get PM's emails/calls done lately.
That Crower you PM'd me about would not be bad, it's still hair small but, step in right direction.
Re: solid roller tell me [Re: RyanJ] #581451
01/14/10 12:20 AM
01/14/10 12:20 AM
Yes.
it sounds like the same type of reply i gave. about 10 degree's more than the one you pm'd me about will do the job very well based on the info i have of your combo.
