325/50/15 on 68-70 B-body? #579081
01/10/10 09:20 PM
01/10/10 09:20 PM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
Anyone running this size drag radial on a stock wheel well, stock width 68-70 B-body? If so, what size wheel and backspacing? How much did you offset the leafs? Thanks
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579082
01/10/10 09:42 PM
01/10/10 09:42 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i would like to know also.i would like theese on my 68 and 70 charger.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 325/50/15 on 68-70 B-body? [Re: Old School] #579083
01/10/10 09:46 PM
01/10/10 09:46 PM
Bellevue, NE
Bellevue, NE
Looking to put 'em on my 70 Charger. I will have the car 2-3'' lower than stock so I don't know if that will be an issue. I found a good deal on a set of 15x10 wheels with 5.5'' backspacing and I'm thinking those might work ... I'm hoping somebody chimes in that's done it.
Re: 325/50/15 on 68-70 B-body? [Re: Old School] #579084
01/10/10 09:47 PM
01/10/10 09:47 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I ran them on my 69 Charger in the past,,,,this was on a 8" rim though,,,( probably should be on a 10" ? )
No issues as far as clearance,,,
I went to a bigger tire,,,295/65/15 and like it alot more,,,really fills the wheel well up,,,no rub issues,,,
Re: 325/50/15 on 68-70 B-body? [Re: 69CHARGERMD] #579085
01/10/10 09:48 PM
01/10/10 09:48 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
ps,,,
you could call Brian,,,at Harlow tire,,,,he is great,,,also a Charger owner,,,and runs Harlow Racing Tire,,,and could tell you pretty quick any issues that you might/could run into...
Re: 325/50/15 on 68-70 B-body? [Re: 69CHARGERMD] #579086
01/10/10 09:59 PM
01/10/10 09:59 PM
Bellevue, NE
Bellevue, NE
I used to run a 295/65/15 on an 8'' wheel, but I want to go back to a 28'' tire. Thanks, I might have to give Brian a call.
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579087
01/10/10 10:01 PM
01/10/10 10:01 PM
Bellevue, NE
Bellevue, NE
Any pics of your Charger with the 325's on her? What was the backspacing on the 8'' wheel? I think it should be on a 10'' tho.
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579088
01/10/10 10:57 PM
01/10/10 10:57 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
yup,,,,i think a 10" is the way to go....
i did find a pic of someone elses car ( none of my own with that particular tire )
325/50/15 on 10" rim
Re: 325/50/15 on 68-70 B-body? [Re: 69CHARGERMD] #579089
01/10/10 11:12 PM
01/10/10 11:12 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
325/50/15 on a 10 " rim is about 5.5" of BS ( should be about 3.5-4" on a 8" rim)
Re: 325/50/15 on 68-70 B-body? [Re: 69CHARGERMD] #579090
01/10/10 11:13 PM
01/10/10 11:13 PM
Carstairs, AB
76Swinger Offline
76Swinger  Offline
Carstairs, AB
Here is a pic of 325/50/15's on my roadrunner. Its a 15X10 with 5.5" BS
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579091
01/10/10 11:17 PM
01/10/10 11:17 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i like the look of a 28" tire on a charger.the 30" looks to big.
Re: 325/50/15 on 68-70 B-body? [Re: 76Swinger] #579092
01/11/10 12:32 AM
01/11/10 12:32 AM
Bellevue, NE
Bellevue, NE
Any side pics? How much room do you have between the tire and quarter/wheelhouse? I want mine to sit a couple inches lower than stock.
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579093
01/11/10 12:42 AM
01/11/10 12:42 AM
Carstairs, AB
76Swinger Offline
76Swinger  Offline
Carstairs, AB
Between the quarter and the tire I have a bout 3/4", between the inside of the tire and the wheelwell I had to bend the flange in so it wouldn't rub I have probably 1/2" space there
Re: 325/50/15 on 68-70 B-body? [Re: 76Swinger] #579094
01/11/10 12:43 AM
01/11/10 12:43 AM
Carstairs, AB
76Swinger Offline
76Swinger  Offline
Carstairs, AB
another
Re: 325/50/15 on 68-70 B-body? [Re: 76Swinger] #579095
01/11/10 12:56 AM
01/11/10 12:56 AM
Bellevue, NE
Bellevue, NE
Sweet, I think I can make it work. Thanks for the pics!
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579096
01/11/10 01:55 AM
01/11/10 01:55 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
On my super bee i have 15 X 10's and 5.5 backspacing mag 500's. I rub on hard corners or going up/down a big hill and slight turn. Dunno how you got around that on the roadrunner. My car has 295/50's (i believe) radial t/a's.
web page
Just have stock springs on it. Have some ss springs in the shed but have yet to get a chance to put them on.
Re: 325/50/15 on 68-70 B-body? [Re: 68KillerBee] #579097
01/11/10 02:37 AM
01/11/10 02:37 AM
Carstairs, AB
76Swinger Offline
76Swinger  Offline
Carstairs, AB
I have ss springs, I did have those problems but once I bent in the lip on the inside of the wheelhouse they stopped rubbing
Re: 325/50/15 on 68-70 B-body? [Re: 76Swinger] #579098
01/11/10 02:56 AM
01/11/10 02:56 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
i'll have to look into that. then i'll be next time i restore in x years.
Re: 325/50/15 on 68-70 B-body? [Re: Charger453] #579099
01/11/10 04:29 AM
01/11/10 04:29 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Most guys have to raise to fit a tire like that. If you want to go lower than stock, I think you are going to run into problems.
Re: 325/50/15 on 68-70 B-body? [Re: 68KillerBee] #579100
01/11/10 04:35 AM
01/11/10 04:35 AM
smyrna,tn
draginmopars Offline
smyrna,tn
if you move the springs into the frame
15x12/ back 5.5 with 67 rear housing can fit a
14x31 (four door) lol http://www.youtube.com/user/peddlingmotors
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
