Re: Generator Help ?
[Re: jimmysarrow]
#578283
01/10/10 11:03 AM
01/10/10 11:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Look at the RV shops, they have a strong slide out (might need to order it) OR go back to your trailer company and ask them, all of the trailers offer a slide out(I believe)
[Re: jimmysarrow]
#578285
01/10/10 11:24 AM
01/10/10 11:24 AM
MR_P_BODY
I have found one place and they want $325.00 , just thought maybe racers have found some other places or come up with some good backyard engineering.
I'm sure that you could go else where(home Depot and others)...weigh the gen and make sure the slides can handle the load
[Re: 68roadrunner]
#578287
01/10/10 08:40 PM
01/10/10 08:40 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I got mine from Haulmark. Around $100, 5 years ago. It is bolted to the trailer floor. I bolted a 3" channel to the slide rail, then bolted the generator to the top of the channel. I use a Mopar bumper jack, for extra support, while at the track. It runs from 6 to 10 hours a day, at the track.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#578288
01/10/10 08:43 PM
01/10/10 08:43 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I got a pair of slides from a surplus place and made mine.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Dartsport540]
#578289
01/10/10 10:26 PM
01/10/10 10:26 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Looks like your exhaust shoots straight out at the poor guy parked next to you?
[Re: jimmysarrow]
#578298
01/12/10 08:46 PM
01/12/10 08:46 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
I have this brand . I used a piece of 3/4" plywood with holes half way through the same i.d. as the rubber feet o.d. on my 3000i Honda, then secured it with an expired seat belt. Works great.
