Generator Help ? #578282
01/10/10 10:54 AM
01/10/10 10:54 AM
charlotte nc
jimmysarrow Offline OP
charlotte nc
I have a new 32 ft trailer and I want to put my generator in the side cabinet but I want the generator to slide out for maintanance.Do you know of anybody who makes this slide out or how did you make yours?
Re: Generator Help ? [Re: jimmysarrow] #578283
01/10/10 11:03 AM
01/10/10 11:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Look at the RV shops, they have a strong slide out
(might need to order it) OR go back to your trailer
company and ask them, all of the trailers offer a slide
out(I believe)
Re: Generator Help ? [Re: MR_P_BODY] #578284
01/10/10 11:08 AM
01/10/10 11:08 AM
charlotte nc
charlotte nc
I have found one place and they want $325.00 , just thought maybe racers have found some other places or come up with some good backyard engineering.
Re: Generator Help ? [Re: jimmysarrow] #578285
01/10/10 11:24 AM
01/10/10 11:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure that you could go else where(home Depot and
others)...weigh the gen and make sure the slides can
handle the load
Re: Generator Help ? [Re: MR_P_BODY] #578286
01/10/10 11:31 AM
01/10/10 11:31 AM
ky
68roadrunner Offline
ky
to get the slides i went to Moore Industrial Hardware in cinncinati oh. they have a website
i got some pretty heavy # slides that lock in or out, so it can't slide on its own. i think they was about $100 or so for the pair,dont quote me on that.
then i made a metal tray and riveted it to the slides.welded some angle on the outside to anchore it to the trailer.
Re: Generator Help ? [Re: 68roadrunner] #578287
01/10/10 08:40 PM
01/10/10 08:40 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I got mine from Haulmark. Around $100, 5 years ago. It is bolted to the trailer floor. I bolted a 3" channel to the slide rail, then bolted the generator to the top of the channel. I use a Mopar bumper jack, for extra support, while at the track. It runs from 6 to 10 hours a day, at the track.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Generator Help ? [Re: Dartsport540] #578288
01/10/10 08:43 PM
01/10/10 08:43 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I got a pair of slides from a surplus place and made mine.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Generator Help ? [Re: Dartsport540] #578289
01/10/10 10:26 PM
01/10/10 10:26 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Looks like your exhaust shoots straight out at the poor guy parked next to you?
Re: Generator Help ? [Re: cl440] #578290
01/11/10 09:41 PM
01/11/10 09:41 PM
charlotte nc
charlotte nc
That is what I had in mine, Did you lay the shelve slides flat on cabinet floor . Also , good use for the old Mopar jacks.
Re: Generator Help ? [Re: cl440] #578291
01/11/10 09:46 PM
01/11/10 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Now days the NHRA says the generator exhaust must exit
above the trailer... I dont have a currant book to
look up the exact wording
Re: Generator Help ? [Re: MR_P_BODY] #578292
01/11/10 09:57 PM
01/11/10 09:57 PM
Kissimmee Fl.
Kissimmee Fl.
they do but I think its got a lot to do with where your at I have been at 2 National Dragster events her in Fl last year and nothing was said about it I ran my gen just like the 1 in the pic all night
Re: Generator Help ? [Re: dusturbd340W5] #578293
01/11/10 10:33 PM
01/11/10 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know if someone bit&hes about the noise or exhaust
they will tell you to shut it down or put the pipe on it
Re: Generator Help ? [Re: MR_P_BODY] #578294
01/12/10 07:59 AM
01/12/10 07:59 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I made mine also using #200 drawer slides. The first time I built it about 5 years ago I used 1x4 pt that I had laying around and a piece of old countertop from a remodel job. That lasted about 4 years then fell apart. I took the whole thing down to the weld shop and they fabbed a heavy duty metal pan and bolted it to the slides. Then they bolted some 3" aluminum angle to it and I screwed that to the floor. Works fantastic.
here is the new one
Re: Generator Help ? [Re: MegaDart] #578295
01/12/10 08:41 AM
01/12/10 08:41 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
another
Re: Generator Help ? [Re: MegaDart] #578296
01/12/10 09:25 AM
01/12/10 09:25 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
closed
Re: Generator Help ? [Re: MegaDart] #578297
01/12/10 02:18 PM
01/12/10 02:18 PM
Kissimmee Fl.
Kissimmee Fl.
closed
Those look just like the slides I used welded up a frame and weled it to the slides bolted the gen to the frame.
Re: Generator Help ? [Re: jimmysarrow] #578298
01/12/10 08:46 PM
01/12/10 08:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I have this brand . I used a piece of 3/4" plywood with holes half way through the same i.d. as the rubber feet o.d. on my 3000i Honda, then secured it with an expired seat belt. Works great.
Re: Generator Help ? [Re: MegaDart] #578299
01/13/10 07:21 PM
01/13/10 07:21 PM
charlotte nc
charlotte nc
Megadart , that looks like a easy install , where did you buy the slides? Thanks everybody for the help and pictures.
Re: Generator Help ? [Re: MegaDart] #578300
01/14/10 01:31 AM
01/14/10 01:31 AM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
yep same thing i did but i used 4 drawer slides and made a inner frame to mount the drawer slide to and mounted the other half across the frame on the cheap gen.
Re: Generator Help ? [Re: jimmysarrow] #578301
01/14/10 06:49 PM
01/14/10 06:49 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
you can get them at homedepot.
