Re: 727 HP Limits?
[Re: keelsracing]
#578025
01/09/10 11:00 PM
01/09/10 11:00 PM
i'm at 978 hp now with a 727 and no problems, going to try to run one with over 1200 hp in a few months.
Re: 727 HP Limits?
[Re: beezer]
#578029
01/10/10 12:58 AM
01/10/10 12:58 AM
Posts: 4,323 NY NY
340duster340
NY NY
sorry to hi-jack the thread, but what does it cost to build a 727 to handle high HP application?
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
Re: 727 HP Limits?
[Re: 340duster340]
#578030
01/10/10 09:17 AM
01/10/10 09:17 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
just how much HP? i have 2K+$ in mine without convertor.
Re: 727 HP Limits?
#578031
01/10/10 09:53 AM
01/10/10 09:53 AM
Posts: 16,932 NC
440Jim
NC
Now that is some power!
It would be a better question to ask what parts are recommended for the power desired by the original poster. So if he adds that (and application, weight) that would be more informative.
I love my 727, cheap and strong.
Re: 727 HP Limits?
[Re: 340duster340]
#578032
01/10/10 10:10 AM
01/10/10 10:10 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
I bought one from the baddest 727 builder in the world (insert CRT logo here) with the intentions of trying to hold together 1300hp, it was in the 4,500 range with the transbrake, but i really wanted the piece of mind the first few times down the strip that i was going to be ok!
Re: 727 HP Limits?
[Re: JohnRR]
#578035
01/10/10 12:17 PM
01/10/10 12:17 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Torque is what kills them , not HP , that said the diesel world is runnng 1500-1800 ft lbs thru the 47RE which is just an OD version of the 727 ...
Yeah but not to be misleading...you can't make 1500 ft/lbs. on a stock 47/48RE... Not without billet input shafts, valve body, converter, etc...
The point is though, there are parts availible to make a 727 handle a lot of power/TQ.
Re: 727 HP Limits?
[Re: dizuster]
#578036
01/10/10 12:52 PM
01/10/10 12:52 PM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
As said earlier torque is the test. Monte Smith might chime in, as I recall he said he was snapping stock (?)output shafts at 1,000 hp on n2o. To me that sounds like over 1,000 ft lbs of torque at the range they run those motors? I have the same shafts in mine that I started with back in 1980! I have progressed from 600 ft lbs to about 780 ft lbs torque.
Re: 727 HP Limits?
#578037
01/12/10 09:37 PM
01/12/10 09:37 PM
Posts: 767 NW PA
V10nacuda
NW PA
I would also like to see what guys are running... But include the weight the car is racing at!!!! Because I am in the same boat looking for up grades for 850hp & 750tq @ at least 3500+ with driver.
Re: 727 HP Limits?
[Re: keelsracing]
#578038
01/12/10 09:49 PM
01/12/10 09:49 PM
Posts: 5 Monroeville, OH
midnight maniac
Monroeville, OH
I really hate to down the beloved 727. But they just cost to much to build to make them live. I run a TH400 that cost less than 1500 with a brake. It holds up to 917 hp 528 in a 3400lb Road Runner.
'69 Road Runner 528 B-1 headed pump gas. Best 9.39 @ 142. 3320#
Re: 727 HP Limits?
[Re: V10nacuda]
#578039
01/12/10 10:03 PM
01/12/10 10:03 PM
3340 lbs with 4.56 gears, dana 60,ladder bar. 1.28 60 foot now. 835 foot lbs.torque,footbraking.all motor.
http://www.youtube.com/watch?v=g1Sn3zGG_aQ
http://www.youtube.com/watch?v=ApRw9pwDtMQ
Re: 727 HP Limits?
[Re: dizuster]
#578040
01/12/10 10:41 PM
01/12/10 10:41 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I never said a stock one would handle that and I have to believe that those asking and replying to this thread are not ASSuMEing stock either .
Re: 727 HP Limits?
[Re: midnight maniac]
#578041
01/12/10 10:43 PM
01/12/10 10:43 PM
JohnRR
Is that $1500 including adaptors and fabbing up a crossmember? Did you have to cut the Tbar X member ?
Re: 727 HP Limits?
[Re: JohnRR]
#578042
01/13/10 07:00 PM
01/13/10 07:00 PM
midnight maniac
Monroeville, OH
No had another 350 in the adapter and flex plate. We just modified the orignal cross member. But still either way, still cheaper than a 727. Plus if the roller clutch decides to fail you just lose 2nd. gear, Not blow the tran, and possilbly the car to bits.
Re: 727 HP Limits?
#578043
01/13/10 07:55 PM
01/13/10 07:55 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
Don't kid yourself about T-400's and 350's not coming apart. If you have the stock cast drum in them just like the T-flite's that come apart, you will find out first hand what happens if you have a habit of dropping into neutral after the stripe like a lot of people like to do. The engine slows down to an idle speed and stops or slows the input shaft, which allows the output shaft, which is connected solidly to the driveshaft, to spin the planetaries around 2.5 times output shaft speed into an overdrive mode, which could conceivably spin the direct CAST drum to well over 14,000 rpm which can .....well, you know the rest No matter what trans you use, make sure you have a good shield as the girl in this Chevelle found out anything can happen (she did get hurt). http://www.youtube.com/watch?v=rNBMtV_NDfo
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
