727 HP Limits? #578024
01/09/10 10:58 PM
01/09/10 10:58 PM
North Carolina
K
keelsracing Offline OP
K
North Carolina
Biulding a "big bore" 440 stroker but what are the limits for the transmission.
And yes I know this really is not set but would like a-round-about number for HP and Torque.
Re: 727 HP Limits? [Re: keelsracing] #578025
01/09/10 11:00 PM
01/09/10 11:00 PM
i'm at 978 hp now with a 727 and no problems, going to try to run one with over 1200 hp in a few months.
Re: 727 HP Limits? [Re: keelsracing] #578026
01/09/10 11:23 PM
01/09/10 11:23 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I get about 250 runs between rebuilds.
8.30's @3400 lbs
Re: 727 HP Limits? #578027
01/10/10 12:10 AM
01/10/10 12:10 AM
North Eastern New York State
montessa Offline
montessa  Offline
I am making 850HP at 3720lbs and haven't had any problems. Best 60ft at 1.34. Footbraking leaving at 1500 RPM's. Aluminum front drum, steel center pinion, rear bearing support and CRT reverse manual valve body. The only thing that has broken in the trans since switching to the automatic in 91' was the stock shaft. I can't remember if it was the output or input shaft. Pull the trans just about every year to be checked. Most of the time doesn't need anything. This year going to try a transbrake. I guess I'll find the weak spots now!
Re: 727 HP Limits? [Re: montessa] #578028
01/10/10 12:38 AM
01/10/10 12:38 AM
illinois,u.s.
beezer Offline
beezer  Offline
illinois,u.s.
For many years funny cars ran 727's behind blown nitro motors making more power than most guys are making now without the good aftermarket parts that are available today.
Re: 727 HP Limits? [Re: beezer] #578029
01/10/10 12:58 AM
01/10/10 12:58 AM
NY NY
3
340duster340 Offline
NY NY
sorry to hi-jack the thread, but what does it cost to build a 727 to handle high HP application?
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: 727 HP Limits? [Re: 340duster340] #578030
01/10/10 09:17 AM
01/10/10 09:17 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
just how much HP?
i have 2K+$ in mine without convertor.
Re: 727 HP Limits? #578031
01/10/10 09:53 AM
01/10/10 09:53 AM
NC
440Jim Offline
440Jim  Offline
NC
Now that is some power!
It would be a better question to ask what parts are recommended for the power desired by the original poster. So if he adds that (and application, weight) that would be more informative.
I love my 727, cheap and strong.
Re: 727 HP Limits? [Re: 340duster340] #578032
01/10/10 10:10 AM
01/10/10 10:10 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I bought one from the baddest 727 builder in the world (insert CRT logo here) with the intentions of trying to hold together 1300hp, it was in the 4,500 range with the transbrake, but i really wanted the piece of mind the first few times down the strip that i was going to be ok!
Re: 727 HP Limits? [Re: 440Jim] #578033
01/10/10 10:17 AM
01/10/10 10:17 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Joe Chrisman aka Tranzact has been running one for years in his 2000plus horsepower car with no troubles..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: 727 HP Limits? [Re: FASTFISH420] #578034
01/10/10 12:05 PM
01/10/10 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Torque is what kills them , not HP , that said the diesel world is runnng 1500-1800 ft lbs thru the 47RE which is just an OD version of the 727 ...
Re: 727 HP Limits? [Re: JohnRR] #578035
01/10/10 12:17 PM
01/10/10 12:17 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah but not to be misleading...you can't make 1500 ft/lbs. on a stock 47/48RE... Not without billet input shafts, valve body, converter, etc...
The point is though, there are parts availible to make a 727 handle a lot of power/TQ.
Re: 727 HP Limits? [Re: dizuster] #578036
01/10/10 12:52 PM
01/10/10 12:52 PM
gregsdart Offline
gregsdart  Offline
As said earlier torque is the test. Monte Smith might chime in, as I recall he said he was snapping stock (?)output shafts at 1,000 hp on n2o. To me that sounds like over 1,000 ft lbs of torque at the range they run those motors?
I have the same shafts in mine that I started with back in 1980! I have progressed from 600 ft lbs to about 780 ft lbs torque.
Re: 727 HP Limits? #578037
01/12/10 09:37 PM
01/12/10 09:37 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
I would also like to see what guys are running... But include the weight the car is racing at!!!!
Because I am in the same boat looking for up grades for 850hp & 750tq @ at least 3500+ with driver.
Re: 727 HP Limits? [Re: keelsracing] #578038
01/12/10 09:49 PM
01/12/10 09:49 PM
Monroeville, OH
midnight maniac Offline
Monroeville, OH
I really hate to down the beloved 727. But they just cost to much to build to make them live. I run a TH400 that cost less than 1500 with a brake. It holds up to 917 hp 528 in a 3400lb Road Runner.
'69 Road Runner 528 B-1 headed pump gas. Best 9.39 @ 142. 3320#
Re: 727 HP Limits? [Re: V10nacuda] #578039
01/12/10 10:03 PM
01/12/10 10:03 PM
3340 lbs with 4.56 gears, dana 60,ladder bar.
1.28 60 foot now. 835 foot lbs.torque,footbraking.all motor.
http://www.youtube.com/watch?v=g1Sn3zGG_aQ
http://www.youtube.com/watch?v=ApRw9pwDtMQ
Re: 727 HP Limits? [Re: dizuster] #578040
01/12/10 10:41 PM
01/12/10 10:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I never said a stock one would handle that and I have to believe that those asking and replying to this thread are not ASSuMEing stock either .
Re: 727 HP Limits? [Re: midnight maniac] #578041
01/12/10 10:43 PM
01/12/10 10:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is that $1500 including adaptors and fabbing up a crossmember? Did you have to cut the Tbar X member ?
Re: 727 HP Limits? [Re: JohnRR] #578042
01/13/10 07:00 PM
01/13/10 07:00 PM
Monroeville, OH
Monroeville, OH
No had another 350 in the adapter and flex plate. We just modified the orignal cross member. But still either way, still cheaper than a 727. Plus if the roller clutch decides to fail you just lose 2nd. gear, Not blow the tran, and possilbly the car to bits.
Re: 727 HP Limits? [Re: midnight maniac] #578043
01/13/10 07:55 PM
01/13/10 07:55 PM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
Don't kid yourself about T-400's and 350's not coming apart. If you have the stock cast drum in them just like the T-flite's that come apart, you will find out first hand what happens if you have a habit of dropping into neutral after the stripe like a lot of people like to do.
The engine slows down to an idle speed and stops or slows the input shaft, which allows the output shaft, which is connected solidly to the driveshaft, to spin the planetaries around 2.5 times output shaft speed into an overdrive mode, which could conceivably spin the direct CAST drum to well over 14,000 rpm which can .....well, you know the rest
No matter what trans you use, make sure you have a good shield as the girl in this Chevelle found out anything can happen (she did get hurt). http://www.youtube.com/watch?v=rNBMtV_NDfo
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
