big tube small-block headers for a duster ???? #576294
01/07/10 08:58 PM
01/07/10 08:58 PM
@ the shop
E
E-85 408 DART Offline OP
E
@ the shop
what headers are you guys running on stroker smallblocks in the a-body. pictures would be great. i'm running a moroso pan and a scattersheild .doesn't seem to be many options if you want a tube bigger than 1 5/8s
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: big tube small-block headers for a duster ???? [Re: E-85 408 DART] #576295
01/07/10 09:23 PM
01/07/10 09:23 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I had to build my own set.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: big tube small-block headers for a duster ???? [Re: E-85 408 DART] #576296
01/07/10 09:27 PM
01/07/10 09:27 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I have run Hooker Super Competition 5204 1 3/4" primary with the Moroso pan.
Discontinued 5203 (1 7/8") going back on.
Heddman has several in their "Husler" series for SB/A-body (OEM, W-2)
Looks like Hooker is getting out of the SBM line.
There's a rumor TTI might come out with a 1 7/8" header for OEM heads
but, haven't heard or checked lately.
Re: big tube small-block headers for a duster ???? [Re: S/ST 3040] #576297
01/07/10 09:29 PM
01/07/10 09:29 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
5204's here.
Re: big tube small-block headers for a duster ???? [Re: S/ST 3040] #576298
01/07/10 09:31 PM
01/07/10 09:31 PM
Kissimmee Fl.
Kissimmee Fl.
last I heard the TTI's should be out by now
Re: big tube small-block headers for a duster ???? [Re: dusturbd340W5] #576299
01/07/10 09:49 PM
01/07/10 09:49 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i see the guys from headman at local shows..
i totally forgot to ask him ..
i will next time i see them.
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: big tube small-block headers for a duster ???? [Re: E-85 408 DART] #576300
01/07/10 10:39 PM
01/07/10 10:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Hedmans here, 1 7/8". Coated by NitroPlate in Nashville TN .
Re: big tube small-block headers for a duster ???? [Re: justinp61] #576301
01/07/10 10:40 PM
01/07/10 10:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Milodon pan had to be modified.
Re: big tube small-block headers for a duster ???? [Re: justinp61] #576302
01/07/10 11:29 PM
01/07/10 11:29 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
Using Hooker 5322's 2" on an early A body with W5's, some modifications needed.
Bill
1970 Charger R/T 1970 Dart Swinger 340/4spd
Re: big tube small-block headers for a duster ???? [Re: Bill_G] #576303
01/08/10 11:14 AM
01/08/10 11:14 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Headman Husslers 2in tubes with adapter plates for the X heads and adapter plates for the w-2s, individual tubes on a 72 Duster.
Re: big tube small-block headers for a duster ???? [Re: Cheatham] #576304
01/08/10 11:20 AM
01/08/10 11:20 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Tubular Automotive 1 7/8, 3/1/2 collector, coated I have adapter plates for the current W2 heads and J heads. Moroso Pan, 363 ci.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: big tube small-block headers for a duster ???? [Re: E-85 408 DART] #576305
01/08/10 11:34 AM
01/08/10 11:34 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have a set of 2" w/3 1/2" collector Hooker W-2s on my 408 W-5. They are a PITA snake pit,but they work with some patient tweeking,with my Milodon pan and flex plateshield.The adapter plate took a fair amount of work.These also require a powermaster clockable starter.Also a bit of work to keep the collector from exiting into the crossmember.I think they are a bit large( 1 7/8" better?) for my combo but the price was right ,they're coated and they work.
Re: big tube small-block headers for a duster ???? [Re: DavidDean] #576306
01/08/10 01:38 PM
01/08/10 01:38 PM
@ the shop
E
E
@ the shop
i think 1 7/8s would be plenty big for my motor .5204 hookers look interesting .hows the ground clearence . anybody know what tti wants for there 1 7/8s .also whats the benefit of the hustler semi-fenderwells .(ground clearence)
its also kinda suprising but the tti's are about the least $$$ , but also not tuned right.
Re: big tube small-block headers for a duster ???? [Re: Bill_G] #576307
01/08/10 05:48 PM
01/08/10 05:48 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Bill
Did you have to remove the inner fenderwells? post some pics please
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: big tube small-block headers for a duster ???? [Re: 65signet] #576308
01/08/10 09:41 PM
01/08/10 09:41 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
Bill
No you should not have to cut the inner fenderwells, the first 3 tubes on each side are within the frame and the last tube on each side swings out and around the frame rail, they are slip together headers. Sorry I do not have any pictures these are going in a full tube car and had to be cut some to work in it.
Bill
