Page 1 of 6 1 2 3 4 5 6
440 source kit update part 2 #575948
01/07/10 04:53 PM
01/07/10 04:53 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
Piston assemblies were all weighed and were with in +/- 1 Gram. Pistons were measured and dimentions were with in +/- .001 Pin fit was on with approx. .0005+
1971 dodge challenger 500ci 9.70s 1969 superbee 383 4speed numbers matching original redline tires 1970 challenger round tube chassis project
Re: 440 source kit update part 2 [Re: curt jr] #575949
01/07/10 05:06 PM
01/07/10 05:06 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
Connecting rods were measured for center to center length and found to be fairly accurate with in +/- .005. Wrist pin bore to pin clearance was found to be approx. .0005+. Connecting rod large end was found to be Fairly Accurate it maintained that accuraccy with slight variance of .0002+ at the parting lines. Weights at the small end varied +/- 1 gram as did the large end.
Re: 440 source kit update part 2 [Re: curt jr] #575950
01/07/10 05:07 PM
01/07/10 05:07 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
#2
Re: 440 source kit update part 2 [Re: curt jr] #575951
01/07/10 05:24 PM
01/07/10 05:24 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
Notice these rods are supplied with ARP 2000 rod bolts.
Re: 440 source kit update part 2 [Re: curt jr] #575952
01/07/10 05:27 PM
01/07/10 05:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I know I don't know alot about balancing but that all sounds like they were pretty close.
Or are they supposed to be even closer than that?
Re: 440 source kit update part 2 [Re: curt jr] #575953
01/07/10 05:29 PM
01/07/10 05:29 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
The kit was supplied with CB-743 H Clevite Bearings. The oil clearance to crank came up to .0025/.002. The only thing we noticed was the bearing misalignment from the cap to the rod.
Re: 440 source kit update part 2 [Re: curt jr] #575954
01/07/10 05:33 PM
01/07/10 05:33 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
Because of this misalignment the bearing shells extended past the rod surface. this is not a big issue as the bearings had no interferance at the crank radius. all in all the piston rod assembly looked quite well and in spec.
Re: 440 source kit update part 2 [Re: curt jr] #575955
01/07/10 05:34 PM
01/07/10 05:34 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Re: 440 source kit update part 2 [Re: curt jr] #575956
01/07/10 05:37 PM
01/07/10 05:37 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
This is going to be my first complete engine build so bare with me if I make any errors and help me out so that "The Bear" (BG) doesn't run me out of the shop "again"
Re: 440 source kit update part 2 [Re: WILD BILL] #575957
01/07/10 05:47 PM
01/07/10 05:47 PM
Johnstown,PA
curt jr Offline OP
curt jr  Offline OP
Johnstown,PA
Bill, these are very acceptable numbers I double checked on a tri-bar scale that is extremly accurate. The digital reads to the nearest gram but the tri-bar reads with in a .1 of a gram.For this build I feel that +/- a gram is fine. Don't tell BG I was using his tri-bar
Re: 440 source kit update part 2 [Re: curt jr] #575958
01/07/10 06:03 PM
01/07/10 06:03 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Did you say C to C was .005"???
Or is that supposed to be .0005"??
At .005" is out of wack for any motor that is going to -0- deck and running a tight quench.
Re: 440 source kit update part 2 [Re: roadhazard] #575959
01/07/10 07:40 PM
01/07/10 07:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Someone is in big trouble when they get home tonight
Re: 440 source kit update part 2 [Re: B G Racing] #575960
01/07/10 07:43 PM
01/07/10 07:43 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What lube was on the rod bolts, and did you cycle them?
Re: 440 source kit update part 2 [Re: moper] #575961
01/07/10 07:51 PM
01/07/10 07:51 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
This would be my curiosity as well. Were the bolts cycled 3-5 times, the rods "relaxed", then put back together and big ends re-measured? Thats where the offshore rods typically start to show signs of trouble. The rest of the numbers arent bad, but the +/-.005 length is a little out of line, but that is fairly typical with the price point type of components...anyones.
RIP Monte Smith
Re: 440 source kit update part 2 [Re: moper] #575962
01/07/10 07:56 PM
01/07/10 07:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Moly,and yes,when we got the engine the short block was already assembled.Actually it was put together twice,the owner got frustrated and dumped it on us.
Re: 440 source kit update part 2 [Re: B G Racing] #575963
01/07/10 07:57 PM
01/07/10 07:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
smart man
Re: 440 source kit update part 2 [Re: CompWedgeEngines] #575964
01/07/10 08:06 PM
01/07/10 08:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Previous owner had the rod end resize after the short block was assembled the frist time.Curt's check was after two torque cycles.
Re: 440 source kit update part 2 [Re: B G Racing] #575965
01/07/10 08:14 PM
01/07/10 08:14 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Doesnt this throw any usable data out the window?
Re: 440 source kit update part 2 [Re: abodiesonly1] #575966
01/07/10 08:18 PM
01/07/10 08:18 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Not really,no matter who's rod,Source,Oliver or any rod should be checked and sized.
Re: 440 source kit update part 2 [Re: B G Racing] #575967
01/07/10 08:27 PM
01/07/10 08:27 PM
Great Lakes Region
Great Lakes Region
Not sure I follow......
Of all the rotating assemblies mentioned above, you have the added expense of re-sizing the rods?
