Re: 440 source kit update part 2
[Re: curt jr]
#575949
01/07/10 05:06 PM
01/07/10 05:06 PM
Posts: 35 Johnstown,PA
curt jr
Johnstown,PA
Connecting rods were measured for center to center length and found to be fairly accurate with in +/- .005. Wrist pin bore to pin clearance was found to be approx. .0005+. Connecting rod large end was found to be Fairly Accurate it maintained that accuraccy with slight variance of .0002+ at the parting lines. Weights at the small end varied +/- 1 gram as did the large end.
1971 dodge challenger 500ci 9.70s
1969 superbee 383 4speed numbers matching original redline tires
1970 challenger round tube chassis project
[Re: curt jr]
#575953
01/07/10 05:29 PM
01/07/10 05:29 PM
curt jr
Johnstown,PA
The kit was supplied with CB-743 H Clevite Bearings. The oil clearance to crank came up to .0025/.002. The only thing we noticed was the bearing misalignment from the cap to the rod.
[Re: curt jr]
#575954
01/07/10 05:33 PM
01/07/10 05:33 PM
curt jr
Johnstown,PA
Because of this misalignment the bearing shells extended past the rod surface. this is not a big issue as the bearings had no interferance at the crank radius. all in all the piston rod assembly looked quite well and in spec.
[Re: B G Racing]
#575960
01/07/10 07:43 PM
01/07/10 07:43 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
What lube was on the rod bolts, and did you cycle them?
[Re: moper]
#575961
01/07/10 07:51 PM
01/07/10 07:51 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
This would be my curiosity as well. Were the bolts cycled 3-5 times, the rods "relaxed", then put back together and big ends re-measured? Thats where the offshore rods typically start to show signs of trouble. The rest of the numbers arent bad, but the +/-.005 length is a little out of line, but that is fairly typical with the price point type of components...anyones.
RIP Monte Smith
[Re: moper]
#575962
01/07/10 07:56 PM
01/07/10 07:56 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Moly,and yes,when we got the engine the short block was already assembled.Actually it was put together twice,the owner got frustrated and dumped it on us.
[Re: B G Racing]
#575963
01/07/10 07:57 PM
01/07/10 07:57 PM
Quicktree
smart man
[Re: CompWedgeEngines]
#575964
01/07/10 08:06 PM
01/07/10 08:06 PM
B G Racing
Eighty Four, PA
Previous owner had the rod end resize after the short block was assembled the frist time.Curt's check was after two torque cycles.
[Re: B G Racing]
#575965
01/07/10 08:14 PM
01/07/10 08:14 PM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
Doesnt this throw any usable data out the window?
[Re: abodiesonly1]
#575966
01/07/10 08:18 PM
01/07/10 08:18 PM
B G Racing
Eighty Four, PA
Not really,no matter who's rod,Source,Oliver or any rod should be checked and sized.
