Re: What size Carb???
[Re: MoparDan]
#574039
01/05/10 07:51 PM
01/05/10 07:51 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
850DP or maybe something like a quick fuel 950. I have a quick fuel carb and am very pleased with it
[Re: khodne]
#574048
01/06/10 01:01 AM
01/06/10 01:01 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I run a racer Brown 242 @ 50 and 510 lift. My buddy runs the identical comp that you have, and runs about 1 tenth faster in car that's 100 pounds lighter. 9.6:1 440 with eddy heads. Import to realize that a good base engine. (cubes, heads, cam, etc) will only get you part way there. tune(timning, carb mix, and setting) gear, tire, etc.. is just as much part of getting it there.
[Re: khodne]
#574049
01/06/10 06:49 AM
01/06/10 06:49 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
i use a 825 mighty demon on my 440(10.78:1) it has run as quick as 11.35@119this is with a purple 509 hydraulic cam,prepped stealth heads, 1 7/8 hooker comp headers into a 3" system with aero chambers with your extra cubes i'd go hp950,850 mighty demon or step up a little to a hp1050 i am thinking of getting a Prosystems 1050 later this year reasonable price for a custom carb have fun Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#574050
01/06/10 07:38 AM
01/06/10 07:38 AM
Posts: 283 N.E. England
Roppa440
super street
super street
N.E. England
A 850 Mighty Demon probably flows 950cfm. You are going to need at least 950 for that engine.
I run a manual six pack that flows about that much and it is just about right for my "small" 440 that only runs high 11s in a 3950lb car.
See what your manifold vacuum is when you pick a carb. Any more than 2 inches of vac at WOT and the carb is probably too small for drag racing.
Dougs Headers are 2" primary and 3.5" collector. They are more like the size you need.
2002 Chevrolet Corvette 5.7 LS1
2011 Alpha Romeo Giulietta Veloce 1.6 JTD
Because running a Mopar in the UK is getting TOO expensive!!
[Re: bigblock340power]
#574055
01/07/10 01:40 AM
01/07/10 01:40 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I'm running a 416 stroker. I've tried a lot of carbs over the years. But my Quick Fuel 950 gives it just what it needs. My vote the 950.
He needs a carb that will truely flow 950-1000 cfm, a 950hp won't do it, all it is is a opened up 750dp, might work great on a stroked SB, but a stroked BB pushing 500 cubes needs decent CFM, not knocking the 950hp, its a great carb, but not for a combo like that if your after full potential. Thats why i recammemded either the 1000hp or 850 mighty demon, the 1000hp is a spiffied up 850dp, both these carbs flow well into the 900 cfm range. I had a fairly mild 446 with iron heads, it screamed with a set of 2" hooker headers & an 850dp, he has way more then that, plus its a stick car.
