What size Carb??? #574036
01/05/10 07:02 PM
01/05/10 07:02 PM
Wisconsin
K
khodne Offline OP
khodne  Offline OP
K
Wisconsin
I'm wondering what size carburetor to use on a 495 CI stroker? I used the 440 Source kit. Stealth heads, I had the 10 degree locks installed. A Comp Cam xtreme energy high lift .545 cam with duration at .050" of 241 on the intake and 247 on the exhaust. Indy dual plane intake. I'm planing on using TTI exhaust but unsure whether to use the 1 7/8" or 2". Suggestions on the Carburetor; type and size, and the header size will be greatly appreciated.
Re: What size Carb??? [Re: khodne] #574037
01/05/10 07:12 PM
01/05/10 07:12 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
850DP or maybe something like a quick fuel 950. I have a quick fuel carb and am very pleased with it
Re: What size Carb??? [Re: MoparDan] #574038
01/05/10 07:45 PM
01/05/10 07:45 PM
Wisconsin
K
khodne Offline OP
khodne  Offline OP
K
Wisconsin
I have 10 to 1 compression, Four speed, and a Dana with 3.54 gears. I was planing on 295 50 15's for driving and I have 275 60 15 BFG Drag radial's to mess around with.
Using the Summit equation I came up with 870 CFM.
Re: What size Carb??? [Re: MoparDan] #574039
01/05/10 07:51 PM
01/05/10 07:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: What size Carb??? [Re: khodne] #574040
01/05/10 08:19 PM
01/05/10 08:19 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
For mainly street use / occasional track...Try a quick fuel 950, I really believe you will be happy. As far as headers 1"7/8 would be fine (minimum)being they are TTI's; Use 3" exhaust minimum
Re: What size Carb??? [Re: MoparDan] #574041
01/05/10 08:53 PM
01/05/10 08:53 PM
id usa
4spdfury Offline
4spdfury  Offline
id usa
Holley has a carb selector on their website.
Re: What size Carb??? [Re: 4spdfury] #574042
01/05/10 08:57 PM
01/05/10 08:57 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
950hp...
Re: What size Carb??? [Re: khodne] #574043
01/05/10 09:07 PM
01/05/10 09:07 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
850 DP
Re: What size Carb??? [Re: MoparDan] #574044
01/05/10 09:24 PM
01/05/10 09:24 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What size Carb??? [Re: BSB67] #574045
01/05/10 09:24 PM
01/05/10 09:24 PM
Wisconsin
K
khodne Offline OP
khodne  Offline OP
K
Wisconsin
I have a Holley 870 Street Avenger with vacuum secondaries that I had planed on using. After reading the forms it looks like with the 4 speed a double pumper is the way to go.
Re: What size Carb??? [Re: khodne] #574046
01/05/10 11:23 PM
01/05/10 11:23 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
850 mighty demon would be my pick
Re: What size Carb??? [Re: dave571] #574047
01/05/10 11:49 PM
01/05/10 11:49 PM
Wisconsin
K
khodne Offline OP
khodne  Offline OP
K
Wisconsin
what cam's are you guy's using to break into the 11's. In your opinion what kind of Hp and times should I expect?
Re: What size Carb??? [Re: khodne] #574048
01/06/10 01:01 AM
01/06/10 01:01 AM
dave571 Offline
dave571  Offline
I run a racer Brown 242 @ 50 and 510 lift.
My buddy runs the identical comp that you have, and runs about 1 tenth faster in car that's 100 pounds lighter. 9.6:1 440 with eddy heads.
Import to realize that a good base engine. (cubes, heads, cam, etc) will only get you part way there. tune(timning, carb mix, and setting) gear, tire, etc.. is just as much part of getting it there.
Re: What size Carb??? [Re: khodne] #574049
01/06/10 06:49 AM
01/06/10 06:49 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i use a 825 mighty demon on my 440(10.78:1)
it has run as quick as 11.35@119
this is with a purple 509 hydraulic cam,prepped stealth heads, 1 7/8 hooker comp headers into a 3" system with aero chambers
with your extra cubes i'd go hp950,850 mighty demon or step up a little to a hp1050
i am thinking of getting a Prosystems 1050 later this year reasonable price for a custom carb
have fun
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What size Carb??? [Re: tex013] #574050
01/06/10 07:38 AM
01/06/10 07:38 AM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
A 850 Mighty Demon probably flows 950cfm. You are going to need at least 950 for that engine.
I run a manual six pack that flows about that much and it is just about right for my "small" 440 that only runs high 11s in a 3950lb car.
See what your manifold vacuum is when you pick a carb. Any more than 2 inches of vac at WOT and the carb is probably too small for drag racing.
Dougs Headers are 2" primary and 3.5" collector. They are more like the size you need.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: What size Carb??? [Re: Roppa440] #574051
01/06/10 04:44 PM
01/06/10 04:44 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
For the money a Pro Form 950HP would be a very good choice. Mine has been VG and just as fast as a 950HP Holley. Jim
Re: What size Carb??? [Re: khodne] #574052
01/06/10 07:18 PM
01/06/10 07:18 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Nice combo. I think that monster would like an
Double pumper 850-870, (maybe a flowed version to
950 cfm, IF IT'S ROWED UPSTAIRS QUITE OFTEN), 2"
primary headers (36-38" length), 12" collector
length, necked to a 3" exhaust. (I would include
a crossover in the system, if running a closed
exhaust system on street/strip. More power!)
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: What size Carb??? [Re: Roppa440] #574053
01/06/10 08:16 PM
01/06/10 08:16 PM
Wisconsin
K
khodne Offline OP
khodne  Offline OP
K
Wisconsin
The Doug's Header's look good from the posts I've read. I had never looked at them before. TTI's have gotten so out of line with their pricing. A few years ago my dad put them on his 440, he thought he had paid around $650-$700. Now they are $871.
Re: What size Carb??? [Re: khodne] #574054
01/06/10 08:39 PM
01/06/10 08:39 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I'm running a 416 stroker. I've tried a lot of carbs over the years. But my Quick Fuel 950 gives it just what it needs. My vote the 950.
Re: What size Carb??? [Re: bigblock340power] #574055
01/07/10 01:40 AM
01/07/10 01:40 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
He needs a carb that will truely flow 950-1000 cfm, a 950hp won't do it, all it is is a opened up 750dp, might work great on a stroked SB, but a stroked BB pushing 500 cubes needs decent CFM, not knocking the 950hp, its a great carb, but not for a combo like that if your after full potential. Thats why i recammemded either the 1000hp or 850 mighty demon, the 1000hp is a spiffied up 850dp, both these carbs flow well into the 900 cfm range. I had a fairly mild 446 with iron heads, it screamed with a set of 2" hooker headers & an 850dp, he has way more then that, plus its a stick car.
