Re: Block Rust....
[Re: dart_73_br]
#573622
01/05/10 08:15 AM
01/05/10 08:15 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Hello guys,
how to clean this block rust before honing it ?!
Could do a sandblasting !?
I hope you are not expecting to just hone that and put some rings in it...that looks like it needs to be hot tanked, then bored and honed.....
Re: Block Rust....
[Re: dart_73_br]
#573625
01/05/10 10:53 AM
01/05/10 10:53 AM
Posts: 627 IN
BIG BEAR
IN
Sure will be bored and honed.
Hot tanked is the same as a chemical/acid bath ?!
This was done but just removed the grease and oils. Not the rust.
Any kind of treatments ?!
I would throw it in a shot blast machine but you will have to do some machining. I definatly would not sandblast it.
Re: Block Rust....
[Re: BIG BEAR]
#573626
01/05/10 12:10 PM
01/05/10 12:10 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
good old fasion elbo grease and some OSPHO then rinse and scrub with dish soap,then paint right away.
Re: Block Rust....
[Re: bonefish]
#573627
01/05/10 12:18 PM
01/05/10 12:18 PM
Re: Block Rust....
[Re: ScottSmith_Harms]
#573630
01/05/10 01:41 PM
01/05/10 01:41 PM
Posts: 282 Stockholm,SWEDEN
The Nutcracker
Stockholm,SWEDEN
Ice blast it! Here in Sweden we hava some companys blasting with ice instead of sand. Perfect! Leaves nothing to clean.
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: Block Rust....
#573632
01/05/10 02:30 PM
01/05/10 02:30 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
DYI clean up at home.
1 50lb bag of dry molasses (available at feed stores, horeses eat it), one big plastic tub with lid, fill with water, let it ferment for a couple weeks (warmer the better), add block, let it sit for a couple more weeks with a tight lid (it reeks, must be outside). Remove clean block.
here's what they're talkin about. this is from resto forum... http://www.massmopar.com/yabb/YaBB.pl?num=1135525788
On another note, my sister is going to sao paolo this spring for a couple of weeks to do a poultry experiment. I go to school at Mizzou(Columbia, Missouri) where I work and know a few Brazilians from Sao Paolo.
Re: Block Rust....
[Re: 68KillerBee]
#573633
01/05/10 02:45 PM
01/05/10 02:45 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Nice!
Re: Block Rust....
[Re: dart_73_br]
#573635
01/05/10 05:40 PM
01/05/10 05:40 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
Molasses.
Molasses ???
Yeah! It really works!
Thatīs chemistry!
i like the molasses idea but what do you do with the stuff when you're done? how do you get rid of it?
Re: Block Rust....
[Re: 9secondsatellite]
#573636
01/05/10 05:41 PM
01/05/10 05:41 PM
Feed it to your horse, of course!
