Block Rust.... #573618
01/05/10 07:40 AM
01/05/10 07:40 AM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello guys,
how to clean this block rust before honing it ?!
Could do a sandblasting !?
Re: Block Rust.... [Re: dart_73_br] #573619
01/05/10 07:40 AM
01/05/10 07:40 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
2
Re: Block Rust.... [Re: dart_73_br] #573620
01/05/10 07:41 AM
01/05/10 07:41 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
3
Re: Block Rust.... [Re: dart_73_br] #573621
01/05/10 07:51 AM
01/05/10 07:51 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I wouldn't sand blast a block. Too much chance of some sand getting trapped somewhere. Shot blast maybe?
Re: Block Rust.... [Re: dart_73_br] #573622
01/05/10 08:15 AM
01/05/10 08:15 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Hello guys,
I hope you are not expecting to just hone that and put some rings in it...that looks like it needs to be hot tanked, then bored and honed.....
Re: Block Rust.... [Re: Sixpak] #573623
01/05/10 08:28 AM
01/05/10 08:28 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Hello guys,
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Block Rust.... [Re: MoparforLife] #573624
01/05/10 09:07 AM
01/05/10 09:07 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
Sure will be bored and honed.
Hot tanked is the same as a chemical/acid bath ?!
This was done but just removed the grease and oils. Not the rust.
Any kind of treatments ?!
Re: Block Rust.... [Re: dart_73_br] #573625
01/05/10 10:53 AM
01/05/10 10:53 AM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
I would throw it in a shot blast machine but you will have to do some machining. I definatly would not sandblast it.
Re: Block Rust.... [Re: BIG BEAR] #573626
01/05/10 12:10 PM
01/05/10 12:10 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
good old fasion elbo grease and some OSPHO then rinse and scrub with dish soap,then paint right away.
Re: Block Rust.... [Re: bonefish] #573627
01/05/10 12:18 PM
01/05/10 12:18 PM
Molasses.
Re: Block Rust.... #573628
01/05/10 12:38 PM
01/05/10 12:38 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Molasses.
Molasses ???
Re: Block Rust.... [Re: dart_73_br] #573629
01/05/10 01:04 PM
01/05/10 01:04 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
DYI clean up at home.
1 50lb bag of dry molasses (available at feed stores, horeses eat it), one big plastic tub with lid, fill with water, let it ferment for a couple weeks (warmer the better), add block, let it sit for a couple more weeks with a tight lid (it reeks, must be outside). Remove clean block.
Re: Block Rust.... [Re: ScottSmith_Harms] #573630
01/05/10 01:41 PM
01/05/10 01:41 PM
Stockholm,SWEDEN
The Nutcracker Offline
Stockholm,SWEDEN
Ice blast it! Here in Sweden we hava some companys blasting with ice instead of sand. Perfect! Leaves nothing to clean.
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: Block Rust.... [Re: The Nutcracker] #573631
01/05/10 02:10 PM
01/05/10 02:10 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
White vinegar (5% acidic) also works well. I used this to remove residual rust and crud in my cooling jackets that resisted two hot tankings. The vinegar is cheap (about a $1.50 per gal) and rinses off with water. If you decide to do your cooling jackets you need to put the motor on one side at a time on a motor stand. Then buy some cheap rubber expansion plugs to seal the core holes. Then just fill from the water pump port with vinegar untill full. A couple of days will do it. You'll be surprised at what comes out.
Re: Block Rust.... [Re: ScottSmith_Harms] #573632
01/05/10 02:30 PM
01/05/10 02:30 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
here's what they're talkin about. this is from resto forum... http://www.massmopar.com/yabb/YaBB.pl?num=1135525788
On another note, my sister is going to sao paolo this spring for a couple of weeks to do a poultry experiment. I go to school at Mizzou(Columbia, Missouri) where I work and know a few Brazilians from Sao Paolo.
Re: Block Rust.... [Re: 68KillerBee] #573633
01/05/10 02:45 PM
01/05/10 02:45 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Nice!
Re: Block Rust.... [Re: dart_73_br] #573634
01/05/10 02:53 PM
01/05/10 02:53 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Molasses.
Molasses ???
Yeah! It really works!
Thatīs chemistry!
Re: Block Rust.... [Re: dart_73_br] #573635
01/05/10 05:40 PM
01/05/10 05:40 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
Molasses.
Molasses ???
Thatīs chemistry!
i like the molasses idea but what do you do with the stuff when you're done? how do you get rid of it?
Re: Block Rust.... [Re: 9secondsatellite] #573636
01/05/10 05:41 PM
01/05/10 05:41 PM
Feed it to your horse, of course!
Re: Block Rust.... #573637
01/05/10 05:43 PM
01/05/10 05:43 PM
alaska,usa
9
alaska,usa
i guess in my case it would be a moose.
