B-Body Suspension #569751
01/02/10 12:17 PM
01/02/10 12:17 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I had my Satellite(GTX Clone) up to about 140 mph yday. I noticed that the car was rolling lft to rght a little. I have the original shocks from 40 years ago on thefront and some new Monroe shocks on the rear. I have a front sway bar to install but have not as of yet. Do I need a rear sway bar as well? And do I ned to replace all shocks with KYB's? I replaced torsion bars last year to handle the front end weight of the 440 but didnt change shocks. What can help keep this car on the road and improve handling without breaking the bank?
Re: B-Body Suspension [Re: roy2345] #569752
01/02/10 12:25 PM
01/02/10 12:25 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Were you at the drag strip or a closed race course? If so, you should have your entire suspension updated if you're going to be racing. If not, you can fix your problem by not going 140 mph. Seriously, If you're going that fast public Highways, just stop!
Re: B-Body Suspension [Re: StealthWedge67] #569753
01/02/10 01:07 PM
01/02/10 01:07 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Nah I was at a race trac strip. But even regular driving I would like a more modern ride.
Re: B-Body Suspension [Re: roy2345] #569754
01/02/10 01:37 PM
01/02/10 01:37 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
You were going 140mph on 40 year old shock and suspension....
Step up and get some new parts. KYB's at least all the way around, and swaybar kits are as cheap as $99 now. How much caster is set up on the front end? Are your lca bushing worn? steering box a bit loose? Seriously, look into some upgrade. If not for safety, you would enjoy the better handeling car.
Re: B-Body Suspension [Re: roy2345] #569755
01/02/10 02:15 PM
01/02/10 02:15 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
You need ALL the above if you plan any more 140 mph runs. You are one small stroke of bad luck from destroying that nice car and maybe yourself. Things that you can recover from at 50 mph are major accidents above 80 mph. The rolling left to right a little will be fixed with a front sway bar and shocks that aren't 35 years beyond replacement time. If the front suspension wear items are as old as the shocks they need replacement also.
Re: B-Body Suspension [Re: roy2345] #569756
01/02/10 03:32 PM
01/02/10 03:32 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
The front end was rebuilt with a front end rebuild kit from Just suspension. New bushings,torsion bars etc.My friend says he can adjust my gear box a little and tighten that up. I just didnt put new Shocks on the front. I did on the rear cause I changed the rear ends. But they are just some regular Monroe nothing special. I plan to add a spring or 2 in the leafs in the rear, install front sway bar and get a rear sway bar. Will this allow me to obtain my goal?
Re: B-Body Suspension [Re: roy2345] #569757
01/02/10 03:52 PM
01/02/10 03:52 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
You were doing 140 mph at the drag strip? That car is definitely quick to be going through the traps like that.
Re: B-Body Suspension *DELETED* [Re: roy2345] #569758
01/02/10 03:52 PM
01/02/10 03:52 PM
Puyallup, WA
Puyallup, WA
Post deleted by GEnsrud
Re: B-Body Suspension [Re: Lefty] #569759
01/02/10 03:58 PM
01/02/10 03:58 PM
germany
440sat72 Offline
440sat72  Offline
germany
Looks like its Time for a Complete Suspension rebuild kit like offered from just suspension or other vendors. And maybe you should take a look at the brakes, too if you havent already.
Re: B-Body Suspension [Re: 440sat72] #569760
01/02/10 04:50 PM
01/02/10 04:50 PM
Georgia,Douglasville
streaker Offline
streaker  Offline
Don't forget Georgia's new super speeder law went into effect Jan. 1.
I said Don't look Ethel, It was too late
Re: B-Body Suspension [Re: StealthWedge67] #569761
01/02/10 05:53 PM
01/02/10 05:53 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Look dude, I'm not stupid and don't attack my persona when you know nothing about me. Where I was yesterday was the country. My buddy has a race track on his 350+ acres. Part of that is a straight shot almost like a runway. All of us wanna be racers go down there and run our cars however we want for $10. So talk what you know not what u think!!!
Re: B-Body Suspension [Re: roy2345] #569762
01/02/10 06:04 PM
01/02/10 06:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
At those speeds, air under the car is a factor. I'd be thinking about a front air dam, too, and running the ride height at about 5 degrees nose down. As the previous posts have recommended, good shocks, and as much positive caster as you can put in it.
Re: B-Body Suspension [Re: topside] #569763
01/02/10 06:26 PM
01/02/10 06:26 PM
So Cal
So Cal
Some float at 140 mph doesn't sound that bad. I bet the aero is pushing the front end up a bunch. Then combine that with old front shocks and maybe? not much caster.
Re: B-Body Suspension [Re: roy2345] #569764
01/02/10 06:29 PM
01/02/10 06:29 PM
Puyallup, WA
Puyallup, WA
Fair enough... I retract my post.
Re: B-Body Suspension [Re: StealthWedge67] #569765
01/02/10 08:19 PM
01/02/10 08:19 PM
out front
jerrya Offline
Comin to a Labor Day Telethon
jerrya  Offline
out front
Is the speedometer correct?
Just kidding dude...
Man does not plan to fail... he fails to plan
Re: B-Body Suspension [Re: jerrya] #569766
01/02/10 09:44 PM
01/02/10 09:44 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Ok guys all of you have indicated on what I need to do. I'm on it next week!!! I talked with a guy today that has 727 trannys with overdrive. Opinions on that? Sorry I'm off topic....
Re: B-Body Suspension [Re: jerrya] #569767
01/02/10 09:46 PM
01/02/10 09:46 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
The Coronet R/T was leaving the ground at about 130. Have not done it since.
Re: B-Body Suspension [Re: roy2345] #569768
01/03/10 02:11 AM
01/03/10 02:11 AM
So Cal
So Cal
There's a guy in our club with a 69 ABS plastic spoiler from a 69 Camaro on his 69 Road Runner. Actually look pretty subtle and most people don't reconize it as a Camaro piece. It does't stick down nearly as much as the one topside posted, but it's off the shelf, not too expensive, and because it ABS plastic it will give if you get it caught on something.
Re: B-Body Suspension [Re: autoxcuda] #569769
01/03/10 04:39 AM
01/03/10 04:39 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
There are many things that will make the car drift side to side. Uneven Air pressure in the tires is one. I do hope your tires are V rated or higher.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: B-Body Suspension [Re: roy2345] #569770
01/03/10 09:44 AM
01/03/10 09:44 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would seriously consider one of these.
http://www.gearvendors.com/
Bolts right on shorten your drive shaft (or have new made) and you can lower you gear and still have more top end. Does not take the power a big overdrive unit takes to drive nor does it have the failour issues!
Stock speedos are often off 15 MPH at that speed?? what is your tire size, rear gear, transmission, Torque converter and rpm you hit!
